Onan 12.5jc/3cr-1AA
this thread has 17 replies and has been viewed 690 times
Old 09-09-2017, 11:37:44 AM
DrewE92 DrewE92 is offline
Default Onan 12.5jc/3cr-1AA
Dose anyone know where i can get a replacement distributor? Is there one i can cross reference at a parts store?
Old 09-09-2017, 02:10:11 PM
Default Re: Onan 12.5jc/3cr-1AA
I honestly don't know if there is one available, I doubt it!
The Following User Says Thank You to nothingbutdarts For This Post:
Old 09-09-2017, 02:29:14 PM
wxyoung2008 wxyoung2008 is offline
Email NOT Working
Hang on a while. Some of the guys will probably have some good pre-owned ones that they will let go reasonably.
The Following User Says Thank You to wxyoung2008 For This Post:
Old 09-09-2017, 05:45:07 PM
Ok thanks guys. I pulled this one out got it all cleaned up I believe I got the advance and all back working will find out tonight
Old 09-09-2017, 06:39:39 PM
Handyhiker1 Handyhiker1 is offline
Good news, good luck!
The Following User Says Thank You to Handyhiker1 For This Post:
Old 09-09-2017, 10:14:01 PM
What was wrong with yours?
Old 09-11-2017, 12:33:22 PM
I have had nothing but ignition problems with this thing (found it in a field at a friend's house) surprisingly no rat nest just a couple hundred wasp lol but some destroyed the control box had to be completely rewired, new relays and switches, new coil condenser and plugs, carb gone through finally got it to bust off and it ran alright back firing a little set breaker points and timing started right up ran perfect at put a small load on it and started skipping and miss firing that's when I noticed the breaker cam has some heavy ware and the advance was getting stuck not letting it spring back. Springs probably needs to be replaced and could use a new cap and button but its back together and run pretty good but I haven't put a load on it yet
Old 09-11-2017, 01:55:43 PM
I have this on a JC.
https://www.summitracing.com/parts/p...SABEgIjrfD_BwE
It's pretty much a bolt in change over. You could pull the points plate out of the one you have, then the springs then pull the retaining clip off and attempt to pull the cam assy. off the shaft, clean and lube it reassemble with the Pertronix.
I actually have a recent thread going about a JC dist. I can not get the cam to come off the shaft because of rust, still soaking it!
Old 09-11-2017, 02:06:21 PM
len k len k is offline
Other alternative ideas , like magnet pressed into hole drilled in flywheel, car pickup coil and ignition modual. Might need 2 magnets, moduals, and coils for 4 cylinder engine
https://www.smokstak.com/forum/showthread.php?t=167037
Old 09-13-2017, 12:08:28 PM
labans labans is offline
I don't know what you have tried for the soaking, but I cannot recommend highly enough using a mixture of ATF and Nail Polish at 50/50 ratio and you must shake it for at least a minute after mixing.
I am an automotive machinist and after using everything commercially available for 50 years I found this suggestion and I can tell you that there is NO second place mixture as this is in a class by itself.
