Onan 6.00 JB 3CE/2236AA Schematic Needed
this thread has 23 replies and has been viewed 605 times
Old 09-12-2017, 11:20:30 AM
majoday majoday is offline
Default Onan 6.00 JB 3CE/2236AA Schematic Needed
I was given the above diesel generator. The controller is disconnected. The Starter is missing as are the Oil input parts. My cousin said it was running when it was removed from a tugboat. I would appreciate any advice from those of you who have worked on these kinds of gen sets. Thank you, in advance!
Old 09-12-2017, 11:27:59 AM
Default Re: Onan 6.00 JB 3CE/2236AA Schematic Needed
Any chance of some pictures of where or what the oil input parts that are missing? Do you mean the filler tube with dipstick???
After seeing Max's post is this a 50 HZ unit?
The Following User Says Thank You to nothingbutdarts For This Post:
Old 09-12-2017, 11:29:31 AM
Yes, the filler tube with dipstick. I have not removed it from the truck, but will post pictures, later. Tks!
Old 09-12-2017, 11:37:28 AM
yellowlister yellowlister is offline
I have all your missing parts if you need them, except a starter
Very good generators. Bit loud but hard to kill..
The Following User Says Thank You to yellowlister For This Post:
Old 09-12-2017, 11:54:08 AM
Max Thompson Max Thompson is online now
Your build sheet (such as it is) and diagram should be attached.
The Following 7 Users Say Thank You to Max Thompson For This Post:
Old 09-12-2017, 08:59:50 PM
Well, my upload of photos is tech challenged!
Old 09-12-2017, 09:21:22 PM
I am somewhat challenged by the uploading process, but I am working it!
Old 09-12-2017, 09:51:36 PM
Have you tried to just see if the engine will turn over by hand for the heck of it?
Old 09-12-2017, 11:16:49 PM
I need the oil parts. I also need the fuel filter parts. There may be some sheet metal needs also. Do you know the specs on the starter?
Thanks!
Old 09-12-2017, 11:22:33 PM
Yes. I did that just before dark. My project will be held up by my sons' problems with his flooded house. Harvey gave his house 8" of water (no ins). His asthma prevents him from working on the house. His wife's work place turned out in numbers to remove the sheetrock and all the flooded material. I'll be returning to help.
Onan 30EK-3R8 Schematic / Manual Needed allneon Onan Generators 7 02-28-2017 09:53:31 AM
3-phase wiring schematic needed for Onan 12.0 DJC tyler e Onan Generators 3 11-04-2015 05:34:57 PM
Onan 15JCB Control Schematic Needed fixit4u Onan Generators 2 08-10-2012 07:00:40 PM
DJB3C/2236AA 6KW Wiring diagram needed. oldiron 1952 Onan Generators 4 09-06-2010 12:07:34 PM
Wiring schematic needed for 12kw Onan air cooled proexperts Onan Generators 2 01-14-2008 01:17:35 PM
