The Independent Harvester Serial Number List
this thread has 35 replies and has been viewed 4209 times
Old 02-17-2019, 03:42:44 AM
Ryan Anderson Ryan Anderson is online now
Images: 10
Default Re: The Independent Harvester Serial Number List
Update on the registry:
10 Rockford Built Side shafts (2, 4, 6, 8 HP)
1 Rockford Built Pushrod engine (3 HP)
25 Type C
rudytoottooty,
What is the serial number on your engine?
Dale,
You have the early/late on the hopper lettering backwards. From engines with known serial numbers and pictures in original condition, it looks like the script was first and then the block was later.
GW Eddy,
I don't think I have the serial number for your 1st engine.
Link to Dale's cart thread
Old 02-17-2019, 09:11:54 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
The Independent Harvester Company was liquidated in December 1917 as per this magazine's article.
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
  #23
Old 02-17-2019, 10:33:20 AM
Dale Russell Dale Russell is offline
It is great that we are finally getting all this Info assembled in one place to be available to everyone. Thanks Denis for the Info on the Co. liquidation. Thanks Ryan, I will change the info regarding the early & late use of the decals. Keep the Info coming.
The Following User Says Thank You to Dale Russell For This Post:
  #24
Old 02-17-2019, 11:58:33 AM
Independent Harvester Company 1916 engine ad.
  #25
Old 02-17-2019, 12:01:36 PM
Jeff, that is a nice article and pictures about The Independent Engine. The engine seed that your Dad & Grandpa planted, sprouted and took root, Ha Ha.
Old 04-29-2019, 12:48:35 PM
rudytoottooty rudytoottooty is offline
Ryan,
I have a 2HP Type C Independent on original Cart. Please add it to your Engine Registry. Serial No. 3445.
Thank you,
Rudy
Old 05-01-2019, 12:28:06 AM
Images: 10
Thanks Rudy. This is the latest Type C on the list. The earliest being number 1032.
Does the engine have any of the original name on the hopper left? Is it block letters or script?
Does the name plate say "THE INDEPENDENT HARVESTER COMPANY INC" OR "INDEPENDENT HARVESTER CO LTD"? I have noticed that the later engines say LTD.
There are now 10 sideshafts, 1 3hp pushrod, and 28 Type C on the list. Please keep them coming everybody.
Old 05-01-2019, 08:44:52 AM
Keep up the good work Ryan!
Old 06-04-2019, 01:29:58 AM
Images: 10
We now have the serial number list on the Sandwich Early Day Engine Club website. Always looking for updates and more information. Share what you have.
http://sandwichengineclub.com/sandwi...rvester-plano/
The Following User Says Thank You to Ryan Anderson For This Post:
  #30
Old 06-04-2019, 01:40:43 AM
Images: 10
The picture I have attached has a date of Dec. 1920 with the letterhead of Independent Harvester Company, Ltd. I think we can draw a line in the sand of December of 1917 and the 2 different tags that I have pointed out in post #27.
Name:	1920 Independent.jpg
The Following 3 Users Say Thank You to Ryan Anderson For This Post:
  #31
Old 06-16-2019, 01:58:21 PM
Barry Chorum's Avatar
Barry Chorum Barry Chorum is offline
i picked this type C up this weekend.
The Following 2 Users Say Thank You to Barry Chorum For This Post:
  #32
Old 06-16-2019, 05:32:20 PM
Looks like a nice Engine! Does your engine have the Governor Guard on it? If it does, you are lucky most, were taken off and discarded. Is it on original trucks. Congratulations on your score!
  #33
Old 06-19-2019, 10:42:58 AM
Dale. my engine is on original trucks. it has the crank guard,belt pulley,starting crank,and muffler. i will check the gov. guard
The Following User Says Thank You to Barry Chorum For This Post:
  #34
Old 06-19-2019, 12:46:13 PM
The Gov. Guard was mounted with a 1/4" X 20 stove bolt with a lock washer, but the surface of the mounting leg was cast with a TAPER so the lock washer didn't do its job. What I did was use a SPOTFACER on the area of the 1/4" hole to make it flat on the one that I had and the guard stayed tight after that. Just a tip!
  #35
Old 06-23-2019, 12:29:49 PM
Dale. i will check my engine tonight and let you know. i will post the S/N also
  #36
Old 06-23-2019, 03:00:37 PM
Ryan Anderson is keeping the Serial # list now. Modify the Gov. guard as I suggested & it will stay in place.
International harvester famous 1 hp serial number pt 2 overdriver Antique Gas Engine Discussion 1 09-15-2015 06:00:30 PM
Ottawa Serial Number List? Jonathan Widelo Drag Saw Collectors 14 06-17-2014 09:28:03 AM
Is there a Crossley serial number list Dustin D Ehli Antique Gas Engine Discussion 10 04-19-2008 08:56:09 AM
serial number list? D Whit Antique Gas Engine Discussion 3 11-28-2006 07:20:07 PM
Serial Number List Dean Antique Engine Archives 1 01-15-2001 07:36:58 PM
