Go Back   SmokStak > SmokStak® Antique Engine Community > Model Railroading
Model Railroading All scales, plus Lionel and American Flyer
Model Railroading
The Sundance Central Railroad
this thread has 5 replies and has been viewed 542 times
Old 06-02-2019, 08:24:05 AM
Default The Sundance Central Railroad
The most incredibly detailed model railroad that I've seen. Enjoy!
https://www.youtube.com/watch?v=UPHASpKgRtQ
The Following 10 Users Say Thank You to Mark Schneider For This Post:
Old 06-21-2019, 10:00:04 AM
Ashton Ashton is offline
Default Re: The Sundance Central Railroad
amazing!
The Following User Says Thank You to Ashton For This Post:
Old 06-21-2019, 10:18:16 PM
Having watched this video numerous times I realize that the Locomotive #102 exposed me to several things that I had not seen before.
The engine is tagged "F & C Ry" which could make it a rendition of some of the rolling stock of the Frankfort and Cincinnati Railroad...a 40 mile narrow gauge shortline in Kentucky that never got close to Cincinnati Ohio! "Forty bridges in 40 miles..."
Here's a couple of computer screen shots...
1. This is the first time I have seen a spark arrestor of this design. Those moose horns mounted by the headlamp add an interesting touch!
2. Both the externally mounted counterbalances mounted on the drivers and the reversing gear are new to me. Anyone know anything about this valve gear?
ID:	337629   Click image for larger version
The Following 2 Users Say Thank You to Mark Schneider For This Post:
Old 06-22-2019, 03:57:32 AM
Maybe if I'd started when I was sixteen..... NOPE! Still not enough time.
Doc
" When in doubt, tell the truth" - Mark Twain
Old 06-23-2019, 11:33:12 PM
The locomotives show clear design of having come from the D&RGW. Most likely they started life as K27, K28, K36 or K37 locomotives of the D&RGW narrow gauge.
Robert
The Following User Says Thank You to Railroads For This Post:
Old 07-08-2019, 10:45:53 PM
I came across this interesting video. "La Trochita" is a narrow gauge railroad in Argentina which appears to running a pair of early Baldwin 2-8-2's that are set up very similar to #102 on the Sundance. The driving wheels are set inside the frame and are driven via the counterweights mounted on the axles outside the frame. The Sundance #102 would appear to be an earlier version of these same locomotives having a slide valve and that unique valve gear. The Argentine units have piston valves and what appears to be a Walschaerts valve gear.
https://www.youtube.com/watch?v=I1zBWpjwGYo
The Following 3 Users Say Thank You to Mark Schneider For This Post:
The Sundance Central RAILROAD G Willikers Steam Stationary Engines, Traction Engines 5 02-11-2019 11:11:39 PM
Railroad Crossing Safety: "The Last Clear Chance" 1959 Union Pacific Railroad Railroads Railroads and Equipment 1 01-21-2019 01:04:11 AM
Virginia Railroads - Louisa Railroad, Virginia Central Railroad, Cheaspeake and Ohio Watt Plow Railroadiana 1 03-25-2018 03:42:16 PM
Sundance 3-Point Brush/Field Mower, 1955? JFLingg Antique Farm Tractors 0 07-03-2015 09:56:17 PM
What railroad was LRR ? Peter Steam Stationary Engines, Traction Engines 3 09-23-2012 01:59:58 AM
