Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Chain Saw Collectors
Chain Saw Collectors Vintage chainsaws and other air cooled gas engine saws, collecting and restoring.
Sally Saw
this thread has 18 replies and has been viewed 3310 times
Old 11-19-2016, 09:33:34 PM
Raydar Raydar is offline
Default Sally Saw
Hello all! I just inherited my great grandfather's Sally Saw. After a lot of Web searching I came up with very little. What I did find was this wealth of knowledge and cool pictures. I will be adding my own, soon.
As it currently sites it looks all original. I have one blade and my aunt called yesterday saying she found the owners manual. The only thing I don't have is the finger that sticks off the cutting head.
My friend and I tried to fire it up but no luck. It has spark but only 60#s of compression. He took the head off and said there is some scaring on the cylinder wall. Think we can hone it out...
Any recommendations for a place to get parts?
Old 11-19-2016, 10:49:44 PM
Edward Cole Edward Cole is offline
Default Re: Sally Saw
Raydar !!! I have a Sally that is near complete I do not have the stand for it
Got it 2 yr. ago I knew where it was But took about 10 year to catch the owner in the mood to sell .. I would like to get a copy of the owners manual.
My saw has a Lauson engine on it . Have not worked to get it running " YET "
I am in Puyallup ED COLE.
Old 11-19-2016, 11:40:28 PM
Tim B's Avatar
Tim B Tim B is offline
Compression doesn't sound too bad, I'll have to check mine. I too would like a copy of the owners manual.
Old 11-20-2016, 12:07:35 AM
Partsman Partsman is offline
Card Sponsor
Hi I am a sponsor on this site. I have engine parts for your saw. Let me know what you need. Thanks Jim; Jim,s Antique Small Engine Parts.
The Following User Says Thank You to Partsman For This Post:
Old 11-20-2016, 12:35:09 AM
The Following User Says Thank You to Raydar For This Post:
Old 11-20-2016, 12:39:35 AM
Old 11-20-2016, 12:51:14 AM
---------- Post added at 08:51:14 PM ---------- Previous post was at 08:41:56 PM ----------
These pics are fresh out of the box that she has lived in for over 25 years! Grams moved into the house in 1990 and none of us remember seeing it. The tank and stand were not mounted but in the box with the motor. The blade was in a separate cardboard sheave. And all 3 boxes were in separate corners of the basement. It's a total wonder that I managed to find it all.
I plan on leaving it as original as possible. Just want it to run.
The Following 3 Users Say Thank You to Raydar For This Post:
Old 11-20-2016, 01:00:24 PM
Ron Weber Ron Weber is offline
I would like a manual too!
Old 11-20-2016, 02:28:46 PM
coyote62ny coyote62ny is offline
60 lbs of compression dont sound bad for an engine that old i would get spark clean the carb you could lap the valves by hand it wont hurt and give it a try it might supprise you
Old 11-20-2016, 10:17:38 PM
Got the valves out today. Think we found the no start issue! And I think the timing may be off, looks like the mag was messed with.
Old 11-20-2016, 10:21:34 PM
Old 11-20-2016, 10:28:05 PM
Here are a few pictures from the Owners Manual. It is missing the cover but the other 36 pages are in good shape.
Center Fold
Front page
Some useful info
Old 12-12-2016, 12:09:32 AM
So the good news is that we got the motor back together. Unfortunately now we don't have any spark. We had it before the tear down but now it's gone. My buddy thinks it's the condenser. Any suggestions?
Old 12-12-2016, 09:00:21 AM
mschreiber mschreiber is offline
that stand swings down to help support weight when cutting? i got 1 and didn't know this. good luck.
Old 12-12-2016, 10:52:45 AM
T Hickok MN T Hickok MN is offline
I think you best have lunch before you go to the woods with Sally!!
Old 12-12-2016, 11:32:42 PM
s100 s100 is offline
If you had spark before but have none now, my first thing to check would be the points. If they are not burned clean them with a piece of paper soaked with electronic contact cleaner. If they are burned file don't sand or replace. Make sure the gap is right. Also inspect for grounded wires, broken wires or a spark plug wire with a break or crack in the insulation. Use an ohm meter to make sure things that are supposed to be grounded are, and things that aren't supposed to be, aren't. Check the coil for continuity, as well. It's easy to check the condenser, but I count it unlikely as the source of your problem. Good luck!
Old 04-07-2018, 04:48:20 PM
hawidmer hawidmer is offline
Hi Raydar: I also have a sally saw, complete and running ,all original, including stand. also looking for owners manual
Old 01-12-2019, 05:42:44 PM
Hi I also have a sally saw, all original, and runs good. would like to get a copy of the owners manual that you have access to. is that possible ?
Old 03-03-2019, 05:38:57 PM
wyalusing jim wyalusing jim is offline
after I got mine running a few years back, I tried it out on a 6x6. took about 3 minutes to get through it, so I'm gonna stick with my stihl.
Sally Saw Tom Winland Chain Saw Collectors 2 01-02-2014 04:35:32 PM
Sally saw and a Mall saw antlers Chain Saw Collectors 6 06-16-2011 09:02:13 PM
I found a Sally Saw - any one have information? economypowerkingfan Farm + Industrial Antiques and Collectibles 13 09-13-2009 09:07:58 PM
I found a Sally Saw - any one have information? economypowerkingfan Chain Saw Collectors 4 03-27-2009 11:02:44 PM
Sally Saw, Clinton Engine? Mike Antique Engine Archives 0 06-08-2001 03:59:23 PM
