Welding Shop
Welding With Cast Iron Filler Rod
this thread has 19 replies and has been viewed 2430 times
Old 01-22-2018, 10:40:41 PM
larry bee larry bee is offline
Default Welding With Cast Iron Filler Rod
I am not a welder but can get by. I have welded on cast iron useing cast iron filler rod and it works great. I am doing something wrong. When the weld is done there appears to be small air holes in the weld. That is okay for just putting a part back together but if you are trying to make it leak proof it is not good. I am using flux maybe to much don't know maybe not the right amount of heat. Any suggestions.
Old 01-23-2018, 12:05:30 AM
sunshineman sunshineman is offline
Default Re: Welding with cast iron filler rod
Hi there
Try doing it with nickel electrodes (manual arc)
Heat parts to cherry red to eliminate all impurities , you should get strong, porosity free welds that are water tight.
Important vintage cast iron may not weld with any process , carbon, sand , etc being present in a high percentage
Test in an area not viewed.
Sometimes cold repairs are the only option-metal stitching, plastic metal fillers, etc.
Regards sunshineman
Old 01-23-2018, 09:14:32 AM
Default Re: Welding With Cast Iron Filler Rod
With gas welding you have to grind through the 'bark' of oxidized metal on the surface before you weld to expose the clean shiny metal. Are you using the correct flux for it? The typical white powdered brazing flux won't work.
Old 01-23-2018, 09:26:51 AM
Old Iron Dave Old Iron Dave is offline
Take a look at Cronatron 211 rod.
Old 01-23-2018, 09:34:53 AM
Acetylene welding with cast iron rods is basically recasting the metal, it can be textured and is almost undetectable. Any nickel or brass will be obvious. I don't know a cure for the porosity, I've been told not to use a grinding wheel to prepare, use a carbide burr, wheel leaves abrasives in the metal.
The Following 3 Users Say Thank You to J.B. Castagnos For This Post:
Old 01-23-2018, 10:05:53 AM
Larry,
I am not a welder either, so take this for what it's worth. I've been using cast iron filler rod to torch weld on occasion for a number of decades. There are a few things I've noticed regarding the porosity. First, there was rarely, if ever, a time when I didn't see at least a few tiny "bubbles" somewhere in the weld. They typically are just bubbles and don't go through. Second, too much localized heating on the weld created irregularities in the bead. Bringing the casting up to a bright red heat at a very minimum alleviated much of trouble. Third, using a reducing flame and never allowing the inner cone to contact the weld or surrounding metal seemed to help with the porosity and also reduced the number of hard spots. I also try to flux the entire weld area as soon as there's enough heat to melt the flux and keep plenty of fresh flux on the rod and ahead of the bead. Using wide vee's, avoiding "box canyons", and flowing the parent metal ahead of the filler all help in creating a uniform weld.
Hopefully someone that actually knows what they're doing will give proper instruction.
Kirk
The Following 4 Users Say Thank You to Kirk Taylor For This Post:
Old 01-23-2018, 11:37:41 AM
Mitch Malcolm Mitch Malcolm is offline
Banner Sponsor
I have done quite a bit of it first use a carbide burr to vee out the crack and go all the way leaving about a 1/8 gap , use the gray high temp flux and most important you have to have a absolute neutral flame I use a # 009 tip on most welds or a 7 for thin metals but i find the neutral flame is the big key.
The Following 2 Users Say Thank You to Mitch Malcolm For This Post:
Old 01-23-2018, 11:43:53 AM
dependable dependable is offline
NIFE-CI stick welding rod works for cast iron in many applications. Stands for nickel ferrite, cast iron, I believe. DC positive or AC. They are pretty expensive..
The Following User Says Thank You to dependable For This Post:
Old 01-23-2018, 01:12:10 PM
Thanks, Mitch.
I've been all over the place with flame characteristics to see what worked best. The next time I weld, I'll go back to a neutral flame and see what happens.
Kirk
Old 01-23-2018, 01:32:43 PM
If you want a strong repair, braze or metal stitch.
Old 01-23-2018, 01:35:37 PM
Forgot to mention Act gas weld. Using a red powder flux. What is a neutral flame
Old 01-23-2018, 01:44:30 PM
LCJudge LCJudge is online now
PALCO 808 (Precision Alloy Company) Rods are great arc welding rods for cast. They weld easily, have a coloration very similar to cast iron (unlike nickel) and are easily machinable. I like them if its something like a bracket. For a cylinder or head crack, I like the old time cast iron torch/stick welding. The rods are about 1/4" square and 16 inches long. When I've used these I use Borax as flux. I agree with JB that its best to use a carbide burr as you won't be left with any contaminants from a emery stone. For welding a cylinder or head, you have to heat the entire item to a temp of probably 1200 or so. I'm no expert by any means, just a hobby shop welder. But, my dad was an expert. He was a certified ship welder, although he only did this for a few years after he got out of WWII. I learned a lot by just watching him......wished I had paid a bit more attention at the time!
http://palcoweldingsupply.com/808.html
I don't work or own stock in PALCO so this is just being passed on as info. My Dad wouldn't use anything but them for arc cast welding and I always thought Dad knew about as much as anyone regarding welding.
Tommy Turner
The Following 6 Users Say Thank You to LCJudge For This Post:
Old 01-23-2018, 06:52:01 PM
Banner Sponsor
Larry a neutral flame has a very round tip in the center part of the flame .
Old 01-23-2018, 06:56:29 PM
Thanks I will try that tonight
Old 01-23-2018, 07:32:37 PM
Ray Freeman Ray Freeman is offline
For a neutral flame increase the acetylene until you get the feather in the flame. Back it of until the feather just comes back to the cone.
The Following User Says Thank You to Ray Freeman For This Post:
Old 01-23-2018, 08:57:51 PM
Greg Mosley Greg Mosley is offline
Greetings, Far as I am concerned welding cast with SMAW and nickel is taboo due to the high carbon content. Magnaflux the repaired area and that will shed the truth. Can you say spider cracks?!? Enuf Said.
The Following User Says Thank You to Greg Mosley For This Post:
Old 01-24-2018, 04:49:10 PM
Langes Machine Shop Langes Machine Shop is offline
Borax is a good flux for steel but does not do well on cast iron. You need a high temp flux for cast iron.
Old 01-26-2018, 02:17:25 PM
There was something that was mixed with the Borax.....but, I never paid attention to what it was and as a result have used straight Borax. What would be the best Flux to use?
I purchased some commercial cast welding flux from a Miller Welding company store but to be honest, I had better luck with the straight Borax than I did their product. One of the best torch cast iron welder's out there was Jerry Abplanalp from KS. Jerry used to make up his own concoction that contained some Borax and 3 or 4 other ingredients. Jerry gave me a cup full of it once and it worked the best of any flux I've used. However, I never got the receipe from Jerry and he's no longer with us.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 01-26-2018, 02:44:49 PM
Wayne A Thackery's Avatar
Wayne A Thackery Wayne A Thackery is offline
Cast Iron Mike's up around Seattle Washington uses this flux for welding cast iron. Mike is in his 80's and knows his stuff! Very reasonable.
Name:	Cast Iron Welding Flux.jpg
Wayne A Thackery
Keizer, Oregon 97303
The Following 3 Users Say Thank You to Wayne A Thackery For This Post:
Old 01-26-2018, 02:58:25 PM
Thanks Wayne. I haven't heard of that flux but will certainly try to get some and use it.
Tommy Turner
Cast iron filler rod Dave Richards Welding Shop 9 04-18-2014 08:59:20 PM
Best Rod for Welding Cast Iron? Grease Monkey Welding Shop 29 01-21-2013 02:28:59 PM
Welding cast iron grub54891 Welding Shop 13 08-09-2010 08:24:10 PM
Tig Welding Cast Iron Chip Watford Welding Shop 10 06-12-2009 11:15:41 AM
Painting Basics - cast iron filler QuinnF Paint Shop 3 07-08-2005 10:55:47 PM
