Welding Shop
Miller AEAD-200LE (Onan CCKA-ms/3848j)
this thread has 6 replies and has been viewed 1054 times
Old 02-14-2018, 04:37:21 PM
Beisert Beisert is offline
Default Miller AEAD-200LE (Onan CCKA-ms/3848j)
Ok one more question, I'm just about finished with it but when I start it it only runs for about 3 seconds and dies does anyone know the carburetor settings for it its got a walbro lua 11 Or any other possibilities it could be? thanks
Old 02-17-2018, 10:19:50 AM
Default Re: miller aead-200le (Onan ccka-ms/3848j)
Well it is getting fuel, its actually spitting a little out of the carb. so now I'm at a loss. Also noticed that I have no voltage going to my highspeed solenoid yes I know I have to get it started and running for it to work but as long as the switch is on shouldn't it be getting power?
Old 02-17-2018, 01:19:44 PM
Vanman Vanman is offline
When it dies, does it shut off cleanly, like cutting the ignition? Or does it stumble and misfire as it dies? What does the exhaust look like as it dies? Spitting fuel out of the carburetor sounds like the float level is too high, or the needle and seat are not sealing. Black smoke from the exhaust would tend to substantiate this.
Old 02-23-2018, 12:51:19 AM
dkamp dkamp is offline
eMail NOT Working
Default Re: Miller AEAD-200LE (Onan ccka-ms/3848j)
Another thing that causes fuel to spit out the carb throat, is having a very restrictive exhaust. Had a '70's CJ-7 with a 304 that simply would not cooperate, and I saw fuel droplets hopping UP out of the carb like popcorn. Thought about it for three days before I had a eureka... took a sawzall and lopped off the exhaust just after the Y pipe, and it woke right up. Mouse crawled up into the catalytic converter and plugged it up really tight.
Old 02-23-2018, 01:01:42 AM
spitting a little out is common on those. is it getting too much down the carb? are the plugs wet?
I'm not sure if the hi idle solenoid is hot unless its running. I wouldn't think you would want the carb in fast speed position when trying to start. it may not get powered up until the machine makes power.
I'll try mine the next time i'm over there.
The Following User Says Thank You to slip knot For This Post:
Old 02-26-2018, 06:51:23 PM
Ok it was the valves they were not even close to spec. But now it will run as long as I hold the start switch but as soon as I let it go it will die the switch is brand new from miller. ANY IDEAS?????
Old 02-27-2018, 05:20:32 PM
valves were way off got it started but it only runs while holding start switch once I let go it dies?
Onan 15.0 JC vs Miller AEAD-200LE As Genset StrikeForce Onan Generators 19 02-09-2016 12:13:16 PM
Onan Miller AEAD 200LE Amps Onan Generators 2 11-25-2015 10:45:23 PM
anybody know what onan motors are in old miller arc welder AEAD 200le carl hite Onan Generators 1 08-28-2015 12:45:14 AM
miller aead 200 LE onan ccka engine dw4tl05 Onan Generators 14 08-31-2013 09:24:56 PM
Need Help with Miller AEAD-200LE Onan Engine hotrog Onan Generators 15 08-21-2013 02:04:56 PM
