Welding Shop
Hobart Powerweld 6500 rebuild
this thread has 3 replies and has been viewed 427 times
Old 12-17-2018, 01:39:04 PM
DJB6.03CE DJB6.03CE is offline
Default Hobart Powerweld 6500 rebuild
Picked up another project
86 Hobart powerweld 6500. Model 6702 Kohler M16S
Not a lot of info on these
Motor runs well. Auto idle not working, and no voltage output in either welding or 110/220 volt .
Previous owner didnít seem to knowledgeable so hopefully something easy to fix.
Motor is super loud even with that big ass muffler on there.
[url=https://flic.kr/p/RuwDCo]
Old 02-18-2019, 06:53:04 PM
Default Re: Hobart Powerweld 6500 rebuild
Iím having a heck of a time getting this armature separated from a Kohler K341.
Itís pressed on a two inch shaft, not tappered as far as I can tell.
Iíve taken out the through bolt and put a rod inside. The inside is threaded so I put a bolt on top to try and push the shaft out/off.
Iíve tried a hammer, also tried a air chisel.
I guess Iíll leave it vertical with some WD40 soaking in the hole.
And maybe a heat gun, I canít use a torch because of the windings and a plastic fan.
Any input would be made ch appreciated.
Old 02-18-2019, 09:05:42 PM
circuitman circuitman is offline
try the grease gun trick, tap the end for a grease gun zerk. screw in & attach the grease gun to it & pump full of grease as much as you can get. put something soft to catch rotor. hit with a dead blow or rubber hammer & she should come right off, if this is a taper.the hydraulic pressure from the grease causes it to release. a little messy but it usually works!!! keep us posted
The Following User Says Thank You to circuitman For This Post:
Old 02-19-2019, 01:57:58 AM
cobbadog cobbadog is online now
I do not know these machines but I would unbolt the short metal flange (adaptor plate) just in front of the fan. This should seperate from the engine and then a fixing bolt may be on that side.
Onan 6500 DN29626 Onan Generators 8 09-03-2016 01:34:26 PM
Onan Commercial 6500 -Joe- Onan Generators 9 02-01-2016 02:13:28 PM
Hoabart Powerweld GR-303 Shop#5404E vibeguy Welding Shop 0 11-10-2012 03:42:35 PM
Help with Briggs Model 23 engine to rebuild or not rebuild jjanitor Garden Tractors / Mowers / Scooters 6 04-14-2012 03:17:44 PM
Commercial 6500 a little help please Mark Lorentz Onan Generators 24 10-28-2009 03:00:02 PM
