Welding Shop
Whats your favorite stick welding rod for cast iron?
this thread has 13 replies and has been viewed 1294 times
Old 03-12-2019, 05:25:40 PM
David Babcock David Babcock is offline
Smile Whats your favorite stick welding rod for cast iron?
I notice a lot of threads here on how to weld cast iron and different ways to do it. When using a stick welder i usually use nickel. But i was just wondering what wonderful rod may be your favorite? Would like to hear about them. Thanks.
Old 03-12-2019, 06:17:57 PM
Nick's Avatar
Nick Nick is offline
Images: 41
Default Re: Whats your favorite stick welding rod for cast iron?
Palco 808. No fancy prep or pre heat, strong and can be machined. Only downside is that it wont blend in to bare unpainted cast.
Old 03-12-2019, 06:42:28 PM
Question Re: Whats your favorite stick welding rod for cast iron?
Not that iam cheap but they are up to $75.00 a lb. Maybe its worth it? Db.
Old 03-12-2019, 09:03:03 PM
old sparky old sparky is offline
super missle rod
Old 03-12-2019, 09:19:43 PM
LCJudge LCJudge is online now
I agree with Nick. Iíve used PALCO 808 since the mid 70ís (before I could drive). Dad was a certified ship welder and 808 was the only thing he would use for cast welding. Iíve heard good things about Muggyweld and a few others but Iíve had good success with the 808ís and will stick with them.
Tommy Turner
Old 03-12-2019, 10:00:08 PM
Dick Brown Dick Brown is offline
Always my favorite 808 palco. Company furnished it
Old 03-12-2019, 10:21:21 PM
I use nickel rod on the bigger items, and my MIG on small items .
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 03-12-2019, 11:57:43 PM
That means Dick Brown has at least 50 lbs of 'em!!
Tommy Turner
The Following 3 Users Say Thank You to LCJudge For This Post:
Old 03-13-2019, 08:34:59 AM
Part of the retirement package . Tt
The Following User Says Thank You to Dick Brown For This Post:
Old 03-13-2019, 09:56:21 AM
I've had several things welded by a friend. He uses nickel rod. It works good except that I can't file it. I want something that I can work. Can you file palco 808? Ron
The Following User Says Thank You to Ronald E. McClellan For This Post:
Old 03-13-2019, 11:36:50 AM
Troll's Avatar
Troll Troll is offline
I typically use Lincoln Ni-55 rod with pre, and post heating. Usually exhaust manifolds or adding turbocharger support brackets to the same on antique heavy trucks. Have repaired broken castings with the same and never had a failure I'm aware of.
Old 03-15-2019, 12:08:25 PM
Sonny Reese Sonny Reese is offline
Certanium rods here. a friend gave me a 5-pound can. requires pre-heating ---slow cooling but will never break again, also machinable. thanks; sonny
Old 03-15-2019, 02:55:00 PM
Alan Svanes Alan Svanes is offline
I had real good success preheating cast and welding with 7018 while it's hot. When I'm done welding I heat it it up again and then cover it up in ash from my fireplace. Some bigger pieces were to hot to hold with my hands after 15 hours in the ash. I've had much better success then welding with nickel.
Alan
Old 03-18-2019, 04:27:08 PM
Langes Machine Shop Langes Machine Shop is offline
Bronze or pure cast iron. Have fixed a lot of things that have all the above mentioned wonder rods. Have to grind all that crap out and braze it. Especially on manifolds!!!!!
The Following 2 Users Say Thank You to Langes Machine Shop For This Post:
Welding Cast Iron cobbadog Smokstak Down Under 25 04-27-2018 05:18:15 PM
Cast Iron Welding crazycajunred Welding Shop 3 05-16-2011 06:53:51 PM
Welding Cast Iron larry Welding Shop 21 02-08-2010 10:38:09 PM
Tig Welding Cast Iron Chip Watford Welding Shop 10 06-12-2009 11:15:41 AM
Stick welding cast iron Mac Leod Welding Shop 9 07-07-2004 01:23:53 PM
