Go Back   SmokStak > SmokStak® Support and Information > Smokstak Forums Meet and Greet
Smokstak Forums Meet and Greet Welcoming Smokstakers New and Old, a place to say a bit about yourself and post a photo if you're really brave. If you have a technical question, please post it on one of our other boards.
New from Southeast Pennsylvania
this thread has 4 replies and has been viewed 899 times
Old 03-24-2017, 09:44:36 PM
D Nickerson D Nickerson is offline
Default New from Southeast Pennsylvania
Hi all. My name is Doug, and have a lot of things. Meaning gas engines and tractors. Not all run, but have them.
---------- Post added at 09:44:36 PM ---------- Previous post was at 09:33:30 PM ----------
Why can I not reply to gas engine archives? I have a Brass tag JD and want to reply to the brass tag thread. It's a 3 horse with original waterloo truck, and would like to know it's value.
Old 03-24-2017, 10:52:11 PM
Charlie1925 Charlie1925 is offline
Default Re: New from south east PA.
D.Nickerson; I think you have to be a Subscriber, not just be Registered. The $ 20.00 a year gives you that and a lot more. Hope this clears that up. Good luck. Roger Weinhold AKA Charlie 1925
Old 03-25-2017, 12:54:47 AM
First forum I've been on that requires money.
Old 03-25-2017, 01:43:57 AM
Harry's Avatar
Images: 312
Default Re: New from Southeast Pennsylvania
The Archives contains old posts from our first boards before 2004. Posting has been turned off because it would be of no use to comment on and re-date these older items. If you need to refer to something there, copy and paste it into your new post. You can use the [quote ][ /quote] commands around the copied text. Remove all spaces from within the [] command. To demonstrate these commands to you, the spaces are inserted to make the command name show.
You can also copy and paste a photo.
You should be making new posts in the Antique Gas Engine Discussion at:
https://www.smokstak.com/forum/forumdisplay.php?f=5
Or, choose the appropriate active forum.
Some forums are paid access, but most are free and open.
If you see on a forum post, that means the thread is closed to new posts.
The Following User Says Thank You to Harry For This Post:
Old 03-26-2017, 04:30:41 PM
Gotcha, thanks
Oil Well Southeast Kansas Leonard Fausset Oil Field Engines & Related Equipment 6 02-23-2017 12:17:15 AM
Southeast shows? Kent Yocum Shows and Swap Meets 2 11-12-2014 08:01:25 PM
Beautiful Day in southeast Pa Galan Hackman Antique Gas Engine Discussion 7 03-11-2013 10:14:33 PM
Hi there from Southeast Michigan Osly71 Smokstak Forums Meet and Greet 2 06-13-2012 07:03:11 PM
Shows in the Southeast 65vette396 Antique Gas Engine Discussion 4 06-29-2006 10:01:30 AM
