1916 Stover Model K
this thread has 1 replies and has been viewed 887 times
Old 11-19-2017, 10:34:44 AM
JerryJ59 JerryJ59 is offline
Default 1916 Stover Model K
Needing some help in restoring a 1916 Stover model K serial# K81605 with a cream separator pulley and a Webster mag:
1--What paint color should this engine be painted? It has a blueish/black color on it now, but I don't think it is original.
2--Are there any repro instruction/manual books out there?
3--How do you lube the main crankshaft bearings, there are no threads for grease cups, just open holes.
This engine also has a lot of movement in piston pin area, rod moves before piston does. I plan on making this engine run a White Mountain ice cream maker someday.
Old 11-19-2017, 12:37:09 PM
Don Tomlinson's Avatar
Don Tomlinson Don Tomlinson is offline
Images: 67
Default Re: 1916 Stover Model K
Nice find, Jerry. The Stover model K is a nice, heavy well built engine. As to your questions, No. 1, Stover engines were a deep red up to the mid teens and then switched to a medium to dark green. in between there were also some that were black but the reasons aren't clear. In addition, some engines were sold to equipment manufacturers who had them painted in their companies preferred colors. On top of that, some were manufactured to be sold by companies in other countries, in other colors. So, unless you can find original paint underneath somewhere, it would be hard to prove. You can find out who the engine was shipped to, and when, by contacting Joe Maurer <toadhill@aeroinc.net> Joe keeps the Stover registry and has access to the original company records. Most were red until about the time yours was made, and most were green after. As to No.2 There are reprinted manuals available from the sponsors on this site, at a very reasonable cost. As to No. 3 The mains were oiled, not greased. The reservoirs on the mains should be packed with cotton waste. Cotton string, like mop string will do nicely nowadays. Twist a few strands down into the holes tightly and pack the remainder on top of them, filling the cup about half to two thirds full. This allows you to add oil each time you run the engine. The oil will be wicked down to the bearing as needed. As for the looseness in the piston pin, it will need to be corrected. You probably need to replace the pin and bushing. Good luck with the new project !
The Following User Says Thank You to Don Tomlinson For This Post:
1916 22 HP stover dcorriea Antique Gas Engine Discussion 6 01-14-2017 11:57:47 AM
Need technical support on my 1916 Stover model T Rhett S Antique Gas Engine Discussion 4 10-17-2014 01:37:08 PM
Jumbo 1916-1923 Webster Mag, what model? agusta74 Antique Gas Engine Discussion 1 07-24-2012 02:44:49 AM
Problem with 4 hp. Stover 1916 year model Brad Rush Antique Gas Engine Discussion 2 08-12-2010 09:36:42 AM
Continental Motors engine Model C4, circa 1916-1919?? wetgundog Antique Autos and Trucks 3 07-05-2009 11:19:35 PM
