IHC MOGUL 10-20 - 1917 Model Parts
this thread has 48 replies and has been viewed 7192 times
Old 11-02-2016, 05:51:27 PM
Stein Rosendal Stein Rosendal is offline
Default IHC MOGUL 10-20 - 1917 Model Parts
We are restoring an IHC MOGUL 10-20 from 1917 and we are looking for some missing parts :-)
These parts are:
- front Wheels
-carburetor
-Governor for engine
-magneto
-seat and spring for seat
Do you have some of these parts I hope to hear from you :-)
Best wishes
Stein Rosendal
Old 11-02-2016, 07:28:56 PM
Phil Johnson's Avatar
Default Re: IHC MOGUL 10-20 - 1917 model Parts
I have a pair of front wheels and a magneto. Shipping may be expensive, especially for the wheels!
Old 11-03-2016, 05:08:03 AM
Hello !
Thank you for answer ! :-)
This is interesting ! :-) Do you have a picture of wheels and magneto ?
Old 11-03-2016, 09:14:36 PM
Chris Epping's Avatar
Chris Epping Chris Epping is offline
Images: 41
Like this carb?
ID:	267217   Click image for larger version
ID:	267218   Click image for larger version
The Following User Says Thank You to Chris Epping For This Post:
Old 11-04-2016, 03:48:03 AM
Originally Posted by Chris Epping View Post
Like this carb?
Hello !
I will check this weekend if it is the same carburettor. Is your carburettor from a 10 - 20 ?
Stein Rosendal
Old 11-04-2016, 09:20:51 AM
Images: 41
Originally Posted by Stein Rosendal View Post
Hello !
Stein Rosendal
Yes, it is 10-20
Old 11-04-2016, 09:34:05 AM
Inverted's Avatar
Inverted Inverted is offline
Default Re: IHC MOGUL 10-20 - 1917 Model Parts
Stien: The carb that Chris has posted is to the mid series production of the 10 - 20 Mogul. I know of three different styles of carbs for the 10 - 20 Moguls. - Ted
Home of Nebraska's Largest Door stop Collection
The Following User Says Thank You to Inverted For This Post:
Old 11-04-2016, 07:13:58 PM
Stein, here are some pics of the Mag and wheels.
ID:	267258   Click image for larger version
ID:	267259   Click image for larger version
ID:	267260   Click image for larger version
The Following 2 Users Say Thank You to Phil Johnson For This Post:
Old 11-04-2016, 07:40:45 PM
AultmanTaylor AultmanTaylor is offline
Hi Phil,
Those aren't mogul wheels I think, all I've seen had smaller hubs whith a thin support for the spokes.
Old 11-04-2016, 09:15:55 PM
halcon halcon is offline
The 10-20 mag has only 1 high tension terminal as it is only 1 cylinder.
---------- Post added at 07:05:03 PM ---------- Previous post was at 07:00:54 PM ----------
The 10-20 mogul mag is single cylinder that mag in the picture is used on a 10-20 titan which is 2 cylinder.
---------- Post added at 07:08:31 PM ---------- Previous post was at 07:05:03 PM ----------
That is a titan 10-20 mag they are 2 cylinder, the mogul 10-20 mag has just one high tension terminal centered in front.
---------- Post added at 07:11:03 PM ---------- Previous post was at 07:08:31 PM ----------
That is a 10-20 titan mag pictured, the mogul mag has only one high tension terminal.
---------- Post added at 07:13:09 PM ---------- Previous post was at 07:11:03 PM ----------
That mag is for a Titan rather than a mogul
---------- Post added at 07:15:55 PM ---------- Previous post was at 07:13:09 PM ----------
Man, I made a mess of that!
The Following 2 Users Say Thank You to halcon For This Post:
1917 Stanley Model 728 Replica Body Info Request SeaMarine1917 Steam Stationary Engines, Traction Engines, Steam Boats 2 12-05-2015 12:44:54 PM
Teagle model 60 magneto--1917 flyguy5219 Magnetos, Ignition Coils and Spark Plugs 0 08-13-2011 06:44:31 PM
1917 Mogul 8-16 Jim Friedrich Antique Farm Tractors 6 01-17-2010 04:48:24 PM
1917 Moline Model C Universal Videos Randy Kvill Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 06-29-2009 03:47:08 PM
1917 Stover Model Y Elwood Antique Gas Engine Discussion 23 02-22-2009 04:28:39 PM
