IHC MOGUL 10-20 - 1917 Model Parts
this thread has 48 replies and has been viewed 7339 times
Old 11-05-2016, 10:34:02 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Default Re: IHC MOGUL 10-20 - 1917 Model Parts
Did you import this or is it an original tractor to Norway?
Tim Colwell
JD & IHC corn sheller and engine collector.
The Following User Says Thank You to Tim Colwell For This Post:
Old 11-06-2016, 04:13:24 AM
Kevin Watson Kevin Watson is offline
Hi I have the correct single pole mag you are looking for and maybe some carb parts. I have a spare large fuel tank if you're needing one I might know of some front wheels but not sure if they're still there. I am looking for gearbox parts or parts to copy.
Could you send me a PM with your email and I will get some photos of what I have
Thank Kevin
The Following User Says Thank You to Kevin Watson For This Post:
  #23
Old 11-06-2016, 05:23:38 PM
Stein Rosendal Stein Rosendal is offline
Originally Posted by cletracker View Post
Hi Stein, long time no see! See you have found yourself a real tractor, gratulations! Can´t be many of them left in Norway. Don´t have any parts but Contact Tore Blom at Rubens, he might have some parts.
Erik Stenvall
Hello Erik ! Yes it's a long time since we met. I have seen om your webside that your crawler collection has been bigger !! :-) I agree with you - this is a real tractor ! :-) My grandfathers first tractor was a Mogul 10 -20 so I am proud to be owner of this one. I Will speak to Tore about parts for Mogul :-)
Stein Rosendal
---------- Post added at 10:23:38 PM ---------- Previous post was at 09:59:27 PM ----------
This is an original tractor that Came to Norway in 1918.
The Following 8 Users Say Thank You to Stein Rosendal For This Post:
  #24
Old 11-09-2016, 11:23:42 AM
Last eveming we started to diamantle the IHC Mogul
10-20. It will be a Long Job. We have to be careful to save all original parts :-)
ID:	267641   Click image for larger version
Old 11-10-2016, 12:00:42 PM
Harry Henderson Harry Henderson is offline
If you need a seat, they turn up on eBay every now and then. If you need seat springs, 3 leaves, I had mine made at Rosedale Road Springs here in the UK. I could get mine copied again when your ready.
---------- Post added at 04:00:42 PM ---------- Previous post was at 03:51:59 PM ----------
I've just looked up where you are based. Am I right in thinking you are just a few miles or KM's south of the Artic Circle? Is this the worlds most Northerly Mogul?
The Following User Says Thank You to Harry Henderson For This Post:
  #26
Old 11-10-2016, 03:19:20 PM
Thank you for answer ! :-) yes I am based about 100 km. South of the artic circle in a town Named Mo i Rana so I think this is maybe the worlds most northerly Mogul 😊
It can be interesting to copy your spring for Seat. I can write a PM to you when I am ready. What was the price to make a spring for seat.
Is your Seat original ? Do you have a picture of Seat and spring ? 😊
Old 11-15-2016, 05:13:49 PM
The work is going on to dismantle steering, front axle and wheels 👍😊
ID:	268122   Click image for larger version
ID:	268123   Click image for larger version
The Following 4 Users Say Thank You to Stein Rosendal For This Post:
  #28
Old 11-15-2016, 09:49:56 PM
halcon halcon is offline
I am not used to seeing this old iron so rusty unless it was buried in wet ground. Was this tractor abandoned near the sea?
Old 11-16-2016, 07:24:14 AM
This tractor has been in a area not long way from the sea 1918 to 1980. From 1980 it has been in a garage.
---------- Post added at 12:24:14 PM ---------- Previous post was at 12:21:59 PM ----------
Someone that knows the original coulor /Paint code for IHC Mogul 10-20, 1917 model ?
The Following User Says Thank You to Stein Rosendal For This Post:
  #30
Old 11-17-2016, 04:59:47 PM
Just to give you some encouragement here's my 10-20 Mogul singing along with a John Deere 52 plough.
The Following 11 Users Say Thank You to Harry Henderson For This Post:
1917 Stanley Model 728 Replica Body Info Request SeaMarine1917 Steam Stationary Engines, Traction Engines, Steam Boats 2 12-05-2015 12:44:54 PM
Teagle model 60 magneto--1917 flyguy5219 Magnetos, Ignition Coils and Spark Plugs 0 08-13-2011 06:44:31 PM
1917 Mogul 8-16 Jim Friedrich Antique Farm Tractors 6 01-17-2010 04:48:24 PM
1917 Moline Model C Universal Videos Randy Kvill Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 06-29-2009 03:47:08 PM
1917 Stover Model Y Elwood Antique Gas Engine Discussion 23 02-22-2009 04:28:39 PM
