Case 500 on Steel New to the Nest
this thread has 36 replies and has been viewed 5911 times
Old 05-29-2018, 10:30:01 PM
J Ware J Ware is offline
Default Re: Case 500 on Steel New to the Nest
Leaving tomorrow morning to go and pick-up the factory steel wheels for the 500, get back and finish up the clutch job then I can get the wheels changed. Jim
The Following 4 Users Say Thank You to J Ware For This Post:
Old 06-09-2018, 10:52:46 PM
I arrived home on the 1st of June with the wheels, and no problems on the entire trip. Meet the father of a fellow stakker and I'd like to thank them for help and generosity.
Last Tuesday I was able to get the clutch installed in the 500. It slid back together easier and better than I thought it would, got it bolted together and pushed back inside the shed because they were calling for heavy rain end of week. I was able to get back to it today, and by 10 pm tonite I drove it for the first time. The clutch will need to be adjusted along with a few other things then on to changing the wheels, that e ill probably be an adventure all in itself. Jim
Old 06-19-2018, 08:07:20 PM
Well it's all ready for its debut this weekend at Natl. Threshers. Last week I buttoned up all the little things, that included repairing a crack in the bottom rad tank, fixing the brakes, and removing the rear wheel weights. That alone took 1400 lbs off this beast. The clutch works great by the way. Leave Thursday morning, hope to run into some fellow Stakkers there and do some visiting. Hope to see you there, Jim
  #34
Old 06-21-2018, 11:29:17 PM
Hope you are having fun down there! I wasn't able to get away this year, but Dad went down and seemed pleased for a Thursday.
Old 06-22-2018, 01:29:35 PM
Weather was great yesterday, had a nice talk with Uncle G, and several other old friends, after the parade was over Wendell put the 30-60 Mogul on the sawmill. Thats the first time it has been labored since it's restoration and the first time since the late 40's early 50's that it has been worked.
Very good line up of prairie tractors this year, Aultman Taylor, Flour City, Rumley,Russel, Avery, Pioneer, even a Little Oak.
But everything is on hold today, the rain has set in, hopefully tomorrow is a better day, except there probably won't be no plowing. Jim
The Following User Says Thank You to J Ware For This Post:
  #36
Old 07-28-2018, 06:20:46 AM
Last Sunday I took the wheels up to Kinde Mi. to a friend's and got the axles out of them. The person I bought them from wasn't able to and didn't want to break the hub trying. Charles used an oxygen lance to burn a hole in the center of the axles, let them cool a few minutes, and with a couple of taps from a small sledge hammer they popped right out. Less than 10 minutes work for 2 1/2 hr drive.
The Following 8 Users Say Thank You to J Ware For This Post:
  #37
Old 07-31-2018, 11:41:18 PM
But if it saves you ten hours of pounding, gas seems awful cheap then.
Case L on Steel Update tristan e Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 09-02-2016 06:18:36 PM
Case VA on full steel? J Ware Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 11-29-2015 10:04:43 PM
S Case steel wheels Lyle Stomp Antique Farm Tractors 0 07-19-2011 09:19:31 PM
Case LA on steel... in Baghdad? Schmuckatelli64 Antique Farm Tractors 21 04-13-2011 01:18:07 PM
Need steel for Case RC. carl wagner Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 06-23-2009 07:41:17 PM
