KTA M&M Minneapolis Moline Twin City Project
this thread has 79 replies and has been viewed 7602 times
Old 10-18-2017, 12:13:21 PM
Russ Hamm's Avatar
Images: 1
Default Re: KTA M&M Minneapolis Moline Twin City Project
I saw an "HC" on it for sure.
Old 11-27-2017, 09:55:24 AM
Russ Hamm's Avatar
Images: 1
This long weekend i managed to weld up the front steel and get rid of those ugly fronts. Still no other progress, only in my mind. The weather has been very warm here and i'm almost put away for winter.
ID:	297127   Click image for larger version
The Following 4 Users Say Thank You to Russ Hamm For This Post:
  #23
Old 11-27-2017, 10:03:50 AM
J Ware J Ware is offline
I got mine shipped to Pat Detwiller to be riveted together and working at getting front axle off so the front spindles can be rebushed. Jim
The Following User Says Thank You to J Ware For This Post:
  #24
Old 11-27-2017, 10:20:29 AM
Russ Hamm's Avatar
Images: 1
When i bought the front cutout hubs they came on an axle with WAYYY better kingpins and bushings. I actually have to remove these wheels again to switch that axle out, going to find a spot in the shop as the pan needs to come off as well.
Old 11-27-2017, 11:54:14 AM
TwinCityMM TwinCityMM is offline
I'm glad to see another surviving MM/Twin City. You have a nice piece to start with that helps a lot. I wish you good luck in your restoration. I have a late MTA that I restored some years back and I absolutely love it. I'll attach some pics.
The Following User Says Thank You to TwinCityMM For This Post:
  #26
Old 11-27-2017, 12:04:23 PM
Here are the pics.
ID:	297138   Click image for larger version
ID:	297139   Click image for larger version
The Following 6 Users Say Thank You to TwinCityMM For This Post:
  #27
Old 11-27-2017, 12:34:11 PM
Russ Hamm's Avatar
Images: 1
I looked at an MTA several weeks ago, on steel. The owner had it split years ago to change the clutch in front of his shed and winter came on so they bolted it back together and pulled it out to the tractor row. Since then the engine seized.
Old 11-27-2017, 02:37:06 PM
That's too bad. These tractors are neat, I really like the lightweight tractor offering s from the big prairie tractor makers. I'd like to have a KTA to go with my MTA someday.
Old 01-15-2018, 03:30:29 PM
Russ Hamm's Avatar
Images: 1
Some word on the internet suggests that 1938 models had red wheels, i'm no M&M expert so I decided to plead ignorance and just move forward.
Got the wheels painted this weekend, as said before the rears are IH 10-20 and the same spline. I'm going to use this setup for now until I find some correct rears, may be visiting ol gleaner south of here on those cutout hubs. I'll always have a use for 10-20 rears at our place regardless.
Still toying with the idea of painting the tractor prairie gold, I REALLY like that gold/red combination.
Old 01-15-2018, 07:57:39 PM
Molinegb Molinegb is offline
1938 KTA would have TC grey wheels same as rest of tractor.. 1938 MM would be cherry red to go with Prairie Gold.
The Following User Says Thank You to Molinegb For This Post:
Minneapolis Moline Twin City KTA Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 31 09-14-2015 07:34:57 PM
Minneapolis Moline Twin City 17-28 Howardh Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 06-07-2012 04:30:26 AM
Rebuild Minneapolis Moline Twin City? Janthetoolman Antique Farm Tractors 9 01-19-2012 05:31:00 PM
Twin City and Minneapolis-Moline G question Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 05-22-2011 09:24:13 AM
Moline & Twin City Carb Info Needed CharlieBiler Antique Farm Tractors 1 09-17-2006 09:56:16 PM
