1935 Twin City FTA
this thread has 33 replies and has been viewed 2455 times
Old 07-02-2018, 03:58:31 PM
Russ Hamm's Avatar
Images: 1
Default Re: 1935 Twin City FTA
A friend came up with another axle, an earlier beam I believe. Otherwise, the front axle is completely apart, I should have kingpin bushings tomorrow and need to decide which way to go.
The tie rod ends are also some kind of hammered and need bushed.
ID:	313508   Click image for larger version
The Following 2 Users Say Thank You to Russ Hamm For This Post:
Old 07-05-2018, 04:42:18 PM
Russ Hamm's Avatar
Images: 1
Got the axle ends rebuilt, got some bushings in, machined on the lathe and pressed into the spindles. A friend gave me these honing kits, "precision hone" company, I don't know how old it is but it actually works pretty well for honing out the kingpin bushings, it would sure be a lot faster with a ream but I don't have anything in that area to use besides one too large and several too small. I think by what little instructions the kit had that this is designed to hone out piston pin holes, maybe wrist pin bushings. Anyway, at work this noon I found that my air drill makes it go a lot quicker than my electric drill at home. Also used sleeve locktite product to insure they wouldn't turn in the bore.
I also had this old sunnex hone lying around and thought about making it do some work, but the belt broke. I think it is actually a rod hone without the stand, I have a whole slew of stones and attachments for it and never have used it since I bought it many years ago.
ID:	313702   Click image for larger version
The Following 4 Users Say Thank You to Russ Hamm For This Post:
  #33
Old 07-09-2018, 09:16:42 AM
Russ Hamm's Avatar
Images: 1
Before we finished plowing I noticed the oil pressure had dropped to 15 psi, so I shut it down for the front axle rebuild and bought some more oil and a filter. Sure enough, the oil was black and thin again, and after removing the filter I found it to be collapsed. Fresh oil, left the new filter out, pressure is back up to 30psi.
ID:	313919   Click image for larger version
ID:	313920   Click image for larger version
  #34
Old 07-12-2018, 02:16:54 PM
Russ Hamm's Avatar
Images: 1
Anyway, the detergent oil episode has made for a great story. When I told Jerry about it this morning he said;
"You gave it a detergent oil enema."
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
New Member of the Twin City Twin Cam Fraternity J Ware Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 22 09-06-2017 12:25:53 PM
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 27 03-19-2017 10:58:08 PM
1935 Twin City 21-32 On Steel 1206SWMO Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 04-01-2015 09:06:33 PM
1935 Twin City FTA 00p225 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-12-2014 09:30:29 PM
