Erd Engine Rebuild
this thread has 1 replies and has been viewed 650 times
Old 06-17-2018, 04:51:01 PM
Rushton1980 Rushton1980 is offline
Question Erd Engine Rebuild
I'm currently stripping the erd engine from my monarch neverslip that I've recently acquired , I have pretty much stripped it for re building but just have the camshaft and cam followers to remove. Unfortunately the cam followers are stuck solid so I'm unable to turn the crankshaft to remove it. This also makes it awkward to get at the followers from underneath. The followers appear to run through a guide which is inserted into the block these guides to me appear to be made from lead or white metal but I'm fairly confident they are lead. As a result of this I'm very loathed to apply any heat to try and free them. Can anyone on here confirm that the guides are in fact lead or white metal ? And has anyone found a successful way of removing these ? Any help appreciated
The Following User Says Thank You to Rushton1980 For This Post:
Old 06-17-2018, 05:26:31 PM
Joe P Joe P is offline
Default Re: Erd Engine Rebuild
The guides are lined with babbit. When we rebuilt the last Erd engines we repoured the babbit then made a rectangular broach out of tool steel to clean them out a little for clearence.
Joe P
The Following User Says Thank You to Joe P For This Post:
1936 IHC LA Engine Rebuild Lvolling Antique Gas Engine Discussion 27 05-21-2018 04:50:00 AM
Dempster? engine rebuild - need help gkeener Unidentified Engines 1 04-15-2014 09:23:31 PM
JD LA Engine rebuild dadam2308 Antique Farm Tractors 7 01-12-2013 11:27:19 PM
Help with Briggs Model 23 engine to rebuild or not rebuild jjanitor Garden Tractors / Mowers / Scooters 6 04-14-2012 03:17:44 PM
Getting an engine running after rebuild jmsolomonson Antique Gas Engine Discussion 30 09-24-2010 06:42:01 PM
