1918 10-20 Titan New Project
this thread has 12 replies and has been viewed 1305 times
Old 06-17-2018, 07:06:01 PM
PB in IN PB in IN is offline
Default 1918 10-20 Titan New Project
Howdy all. It has been a while since I've acquired a piece of iron to post in here again. This is my first early piece that's older then 1924. I'm hoping the vast amount of knowledge on this page can help guide and educate me on getting this old girl back up and running. It is loose but has been sitting since 1975. I know its not all correct but hopefully over time I can find the correct pieces to make it correct. The biggest thing I need to find currently are the rod bearings.
ID:	312641   Click image for larger version
ID:	312642   Click image for larger version
Old 06-17-2018, 07:10:49 PM
Default Re: 1918 10-20 titan new project
More pics of the titan
ID:	312644   Click image for larger version
ID:	312645   Click image for larger version
ID:	312646   Click image for larger version
The Following 3 Users Say Thank You to PB in IN For This Post:
Old 06-17-2018, 07:17:51 PM
Some other pictures
ID:	312652   Click image for larger version
ID:	312653   Click image for larger version
The Following 4 Users Say Thank You to PB in IN For This Post:
Old 06-17-2018, 07:35:32 PM
Card Sponsor
There are a few old automotive machine shops that can rebabbit the shells and rebore them. You might want to look into that. Rob
The Following User Says Thank You to Rob Charles For This Post:
Old 06-17-2018, 08:10:32 PM
Thanks I need to find the shells since they were not reused last time they were repoured
Old 06-17-2018, 11:36:40 PM
Default Re: 1918 10-20 Titan New Project
One big piece of babbit.....
Congrats on the score! Hope she goes together easy and runs well!
Old 06-17-2018, 11:46:02 PM
halcon halcon is offline
Hopefully it wasn't run dry till it hammered the brass out and made a bad mess of the crankshaft. We have machined up new brass shells like those but it is pricey. There has to be some around somewhere.
The Following User Says Thank You to halcon For This Post:
Old 06-18-2018, 06:25:20 PM
Mitch Malcolm Mitch Malcolm is offline
Banner Sponsor
When I did mine I machined new rod bearings out of Bronze trued up the crank with a new file and emerystrip and bored the bearings accordingly it works just fine ..
The Following 2 Users Say Thank You to Mitch Malcolm For This Post:
Old 06-18-2018, 07:04:20 PM
Russ Hamm's Avatar
Images: 1
Nice gearing and sprockets.
Old 06-19-2018, 08:39:39 PM
Thanks I'm impressed at how little wear are on them they look in excellent shape. The chains are in excellent condition as well. Gas tank is completely rotted out on the bottom so have to find someone who can reproduce it and also have to find a watertank, right fender, gear guard, the viewing lid for the oiler and a lid for the air cleaner is what I have found so far I need.
Project engine 2 1/2 IHC Titan Don Oberholtzer Antique Gas Engine Discussion 4 11-09-2017 07:51:57 PM
1918 IHC Titan fenders DanLyle89 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 01-17-2017 12:58:40 PM
1919 10-20 Titan Project Rick Green Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 01-15-2014 10:26:56 PM
10 hp Titan project Mike F Antique Gas Engine Discussion 3 01-12-2009 09:51:35 PM
Titan JR project just got home Ron Davis Antique Engine Photos 1 12-05-2006 06:37:56 PM
