Case 18-32 Crossmount Cylinder Sleeves
this thread has 5 replies and has been viewed 786 times
Old 06-20-2018, 12:10:37 AM
Tjohanson Tjohanson is offline
Default Case 18-32 Crossmount Cylinder Sleeves
Has any one out there had cylinder sleeves (liners) manufactured for a Case 18-32? I have one liner that is broken and two that are deeply pitted. I am looking for any leads as to where to get some and the cost on them. I just started this project and any info is greatly appreciated. Thanks
The Following User Says Thank You to Tjohanson For This Post:
Old 06-20-2018, 01:47:22 AM
Thumbs up Re: Case 18-32 Crossmount Cylinder Sleeves
Welcome to STAK...….
You have come to the right place...…..
Old 06-21-2018, 12:04:23 AM
Gene Williams Gene Williams is offline
Default Re: Case 18-32 Crossmount Cylinder Sleeves
We have bored and sleeved the sleeves on other crossmounts. I would think it would work if there is enough material in the 18-32. You might check in your area for someone who does that type of work, it isn't all that complicated to do (we figured it out)
Old 06-21-2018, 09:33:27 PM
I can not get the one sleeved as it cracked the top of the liner and broke two pieces out of it. I can not find anybody that will atempt to weld it back together so I can try it. I have not had the time to try to weld it together myself.
Old 06-21-2018, 09:49:03 PM
Default Case 18-32 cylinder sleeve replacement part
Old 06-21-2018, 11:19:50 PM
Melling seems to come up quite a bit. They may require an original to measure.
Melling Custom Sleeves
CASE 12-20 Crossmount manifold NEEDED Reeves1665 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 06-05-2015 07:49:48 AM
Case 18-32 crossmount engine/clutch oil seal veroude Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 05-02-2013 03:22:46 AM
18/32 case crossmount chevyman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 08-02-2008 09:55:23 PM
Case CrossMount Spark Plugs Harry Henderson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 08-02-2008 07:31:54 AM
Tractor ID's, Rumely and Case Crossmount KevinF Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 07-19-2006 12:08:51 AM
