Fordson F 1919 with Fordson E27N Manifold and Zenith Vaporizer/Carb
this thread has 0 replies and has been viewed 387 times
Old 07-03-2018, 03:23:23 PM
hkruger hkruger is offline
Question Fordson F 1919 with Fordson E27N Manifold and Zenith Vaporizer/Carb
Hallo
i have just gotten my fordson F started for the first time in 60 years. its pretty original, but it has a e27n carb and manifold on it (and 7 spoke wheels and a badly rebuilt tank). i will change it at some stage but for now i just want to get it to run propery.
i had a problem with too rich fuel. 2 gallons in 10 minutes start and stop. that is fixed now, and i can get the motor to calm down. needle valve is very sensitive.
what i cant do is get any response on the throttle. closed or open makes no difference whatsoever. once i get the tractor to a stable speed, i cant hardly touch the choke
once i get the tractor to a stable speed, i cant hardly touch the choke. i cant open the choke much or it starts running up too high. if i open the choke too much it dies. if i open the needle valve more, i am back at the 2 gallons in 10 minutes problem.
i am not sure what to try next. i can try and replace the diaphragm and replace my paper gaskets with originals, but have been told that that shouldnt influence it that much
any ideas?
Fordson E27N Perkins P6 RustyRelics UK Antique Farm Tractors 3 08-01-2016 08:27:31 AM
Fordson Oi E27N GreasyJohn Smokstak Down Under 6 01-05-2016 07:27:31 PM
Fordson E27N Correct engine oil? E27N Antique Farm Tractors 3 01-11-2012 07:38:16 PM
1923 Fordson Vaporizer choppedjunk Antique Farm Tractors 7 12-21-2010 01:55:10 PM
E27N fordson plow question Alltractorman Antique Farm Tractors 1 03-29-2006 04:43:33 PM
