16-30 Hart Parr Part Needed
this thread has 3 replies and has been viewed 629 times
Old 07-08-2018, 08:41:03 PM
Kelly Barnett's Avatar
Kelly Barnett Kelly Barnett is offline
Images: 15
Default 16-30 Hart Parr Part Needed
I am in need of this casting for my 1926 Hart-Parr 16-30"F". This is the back pivot shaft bearing for the front axle. Mine has a piece of angle iron that was modified to fit. It hadn't fared well over the years. The casting number is 9740A ( I think that is right out of the parts manual). The parts book says that serial numbers 21408 to 26000 used this casting. The 18-36 parts book shows the same part number used on all of them (sn#26001-34999, 85001-... ). The 28-50's show this part on sn#70001-70951). So there should be something out there I would think. Let me know if there is anything out there you can help me with on this search. Thanks
The Following User Says Thank You to Kelly Barnett For This Post:
Old 07-09-2018, 12:13:38 AM
S.Simons S.Simons is offline
Default Re: 16-30 Hart Parr Part Needed
I know someone that could braze it back to new.
Old 07-10-2018, 09:37:14 PM
Brian Flatmoe Brian Flatmoe is offline
Kelly, send me a pm. I probably have what you need.
Old 07-12-2018, 08:52:44 AM
Images: 15
I think I have a bracket located. Only time will tell... One more thing to check off of the "list".
Hart Parr Scotty 2 Smokstak Down Under 3 05-13-2018 08:19:39 AM
Hart-Parr 30-60 Engine Information Needed Elden DuRand Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 29 01-10-2015 03:23:35 PM
Oliver Hart Parr Timing Gear Help Needed Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 05-29-2013 10:56:17 PM
18-36 hart parr help needed Mtype Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 09-23-2006 08:42:18 AM
Hart Parr hottube Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 11-11-2005 11:00:29 PM
