Vintage Tractors Earning a Living
this thread has 21 replies and has been viewed 1473 times
Old 07-09-2018, 05:22:30 AM
JimDoyle JimDoyle is offline
Default Vintage Tractors Earning a Living
I have been thinking, and it was painfull....., I have seen some awesome repairs/restorations of vintage tractors to working condition or essentially brand new. Which led to the thought how many of the these tractors I see still earn a living? I mean from preparing a field prior to planting through to harvesting, or are most just show queens?
The Following User Says Thank You to JimDoyle For This Post:
Old 07-09-2018, 08:56:07 AM
Russ Hamm's Avatar
Images: 1
Default Re: Vintage Tractors Earning a Living
Some of the steel wheeled tractors in our collection will get to do some plowing now and then, that can sure be nearly every year but not many hours.
The first tractor that I bought to use would be our 41 H Farmall, it now has a sickle mower mounted to it for haying. BUT the 350 International utility I bought soon after that gets a workout every year on the small square baler and at our local show I use it a lot besides. This tractor rakes and bales both, ever year without fail.
ID:	313917   Click image for larger version
The Following 2 Users Say Thank You to Russ Hamm For This Post:
Old 07-09-2018, 09:52:03 AM
The old tractors are very reliable if properly maintained. Take a Farmall F-20 or a F-30. Few were really worn out and the F-20 was one of the or the most popular tractor around the mid-west. You could farm 160 to 300 acres with one. However you can no longer make a family living on that small of a conventional farm. Methods have changed so, with moldboard plowing a thing of the past. Modern equipment as sprayers and planters might be adapted to an old Farmall. Used combines with reasonable modern designs are affordable. You'd need to be a good mechanic.
I had a friend with a few riding horses who put up hay completely by hand, mostly from roadsides. He had an IHC Cub with a sickle bar mower and he eventually got an IHC 45 baler. I gave him a side delivery rake which I bought for 25 cents and I loaned him an F-20 and he went to work cutting and bailing roadsides with a lot less labor.
The Following 2 Users Say Thank You to Oilpulled For This Post:
Old 07-09-2018, 10:25:15 AM
There is a large tree nursery here. It has modern equipment, but I often see an old Farmall Cub out scuffling in the new plantings. Perhaps they will allow me to take a picture.
Old 07-09-2018, 04:33:31 PM
DCamp DCamp is offline
I use my '51 Super A for plowing and testing sprayers. My '48 I use at the fairgrounds grading the show rings.
The Following User Says Thank You to DCamp For This Post:
Old 07-09-2018, 05:21:56 PM
EdDarowski EdDarowski is offline
My Farmall Cubs work in the garden, regularly.
Ed
The Following User Says Thank You to EdDarowski For This Post:
Old 07-09-2018, 05:46:26 PM
Wayne Riedlinger Wayne Riedlinger is offline
We put in about 12 acers of grain every year. Most of it gets done with a WD9 and a farmall MD. I keep a few acers worked up with a D J-D or an 18-36 hart parr. Somtimes I use a 15-30 mcormick deering.
The Following 2 Users Say Thank You to Wayne Riedlinger For This Post:
Old 07-09-2018, 06:26:05 PM
Russ Hamm's Avatar
Images: 1
Same here Wayne, and when we are not in a hurry over the years we plow with the old ones.
ID:	313936   Click image for larger version
ID:	313937   Click image for larger version
ID:	313938   Click image for larger version
The Following 7 Users Say Thank You to Russ Hamm For This Post:
Old 07-09-2018, 10:28:47 PM
PFT's Avatar
PFT PFT is offline
Images: 31
I used to haul logs out of the woods with my F12, also used it for raking hay, hauling wagons, and fire wood. My last work for it was mowing the weeds at the edge of the lawn and roadside. Unfortunately, I had to leave it in NY with my brother because I am not allowed to have a yard ornament here in the subdivision in Colorado, so it sits in NY.
PT
The Following 7 Users Say Thank You to PFT For This Post:
Old 07-09-2018, 10:57:18 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
I still use my 350 Farmall quite a bit, mow ditch banks, rake hay and bale hay, run the grain auger and still cultivate corn and beans pulling a 6 row rear mount cultivator. also use the 1206 and 806 for light chores also, no sense wasting the newer big tractors on such little jobs.
The Following 2 Users Say Thank You to FWurth For This Post:
Linn Tractor earning a wage King of Obsolete Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 03-28-2017 10:29:42 AM
Vintage toy farm tractors- Where to post? roysboystoys Antique Farm Tractors 1 02-27-2017 01:57:08 AM
Vintage IH Tractors, Pickup, Toys, Household & Furniture huberman Live Auctions of Engines, Tractors and Old Iron 0 07-25-2014 12:16:25 AM
Atlas Steam tractor & Vintage Ford tractors...June 1...St Louis MO Firewoodguy Live Auctions of Engines, Tractors and Old Iron 0 05-25-2013 07:27:09 PM
Still earning it's keep..... Mark L. Jordan Steam Stationary Engines, Traction Engines, Steam Boats 8 10-26-2007 07:44:42 PM
