Steam Engines
Nagle steam
this thread has 8 replies and has been viewed 1750 times
Old 10-27-2014, 11:52:39 PM
Josh. T. Josh. T. is offline
Default Nagle steam
I am looking for a base for a 5X7 Nagle upright bottle type steam engine. I would also like to know if anyone has a catalogue so I can properly identify the year of my engine.
Old 10-28-2014, 11:28:14 AM
Joe K Joe K is offline
Default Re: Nagle steam
VERY unlikely to find a base. I have a similar problem with an Orr & Sembower 4x4 vertical which had been originally part of a chain grate stoker drive.
My current solution is to put the engine (and it's outboard bearing) on a wooden base done in the "cutting board" style (i.e. 3/4 x 3 flatways and glued/tied together with through rods) with similar constructed stands for the engine base and the bearing base. Not perfect but some who have seen it have commented on the fine workmanship of the base (it's not that good IMHO)
Eventually this will be replaced with a steel weldment which will be filled/painted to simulate the original minus the raised lettering.
I have considered Cat-Tail Foundry who given a pattern, will cast it up. But a pattern is a lot of work - and I don't know the standards to which they require patterns to be made (draw, shrinkage typical, core print requirements if any, etc.) Plus Cat-Tail is a long way aways from Cow Hampshire - and local foundries are almost Unobtanium thanks to he who must not be mentioned and his ilk.
Sometimes home-brew is the best option. Being under steam is the BY FAR best option, however one comes to it.
Good luck,
Joe K
Old 10-29-2014, 07:38:35 PM
Thanks Joe,
I have mine mounted in a similar way, but you never know so I thought I would ask. I have made some patterns and had them cast in bronze and if I can't find an orginal I will do the same.
Thanks Josh
Old 10-31-2014, 12:59:35 PM
PTraubert PTraubert is offline
eMail NOT Working
Post some pictures - I have an old catalog but not sure of date.
Patrick
Old 10-31-2014, 07:11:31 PM
John Deck John Deck is offline
Call cattail and ask the are down to earth and easy to visit with
Old 10-31-2014, 08:19:27 PM
David Clark David Clark is offline
I have a 1906 Nagle cat. but it doesn't list a 5 x 7 upright.
Old 11-01-2014, 10:25:51 AM
My engine isn't as big as yours and needed a base. It was front heavy so it had to be extended past the flywheel. I don't know the make of the engine. Note the rotating valve. It runs great! Ron
Name:	RED VERT STEAM.jpg
ID:	209831   Click image for larger version
Name:	RED VERT STEAM 3.jpg
Old 11-01-2014, 04:52:03 PM
Richard Miller Richard Miller is offline
These images were taken from a Nagle Engine Catalog.
ID:	209865   Click image for larger version
Old 11-03-2014, 01:58:01 PM
eMail NOT Working
This is a Rocking Valve engine that, I think, places its age well before 1900. Maybe 1870s or 1880s. My catalog #80 does not have it.
Looking for information on a NAGLE steam engine. hitandmissguys Steam Stationary Engines, Traction Engines, Steam Boats 8 12-01-2011 07:47:07 PM
Nagle Pictures obanta Steam Stationary Engines, Traction Engines, Steam Boats 4 06-06-2007 01:28:47 PM
T.M. Nagle Bulzar Steam Stationary Engines, Traction Engines, Steam Boats 3 03-14-2005 01:04:45 AM
Nagle Stationary Steam Engine Bob Sanders Steam Stationary Engines, Traction Engines, Steam Boats 0 12-06-2002 12:13:20 PM
Nagle Steam engine dave in PA Steam Stationary Engines, Traction Engines, Steam Boats 0 04-01-2002 09:45:21 PM
