Steam Engines
Governor... But what is it for?
this thread has 3 replies and has been viewed 640 times
Old 12-10-2017, 10:39:07 AM
Tony Glaser Tony Glaser is offline
Default Governor... But what is it for?
I know I've had this on Harry's page but I'm not sure if it had this picture in the steam section. I am wondering what it fits and possibly a ballpark value. I'm not familiar with steam as I'm into hit and miss engines. Any help is appreciated. Thanks all. -Tony-
Old 12-10-2017, 11:59:10 AM
Images: 2716
Default Re: Governor.. But what is it for?
Tony, I'd bet a nickel that it came off of a smaller gas tractor's engine. Gary
The Following User Says Thank You to 20 Reeves Highwheeler For This Post:
Old 12-10-2017, 12:22:10 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Those covered pickering type were made for use on many gas tractors. If belt driven, Eagle tractors used them. Yours looks to be driven from the end of the camshaft. also there looks to be a control arm on it. All steam governors had a direct mounting on the steam valve, so I think we can rule out any steam use.
The Following 2 Users Say Thank You to FWurth For This Post:
Old 12-10-2017, 03:15:01 PM
Glenn Gieszler Glenn Gieszler is offline
If you were to peer into the early seperator history you will also see this type used on the early feeders used as a governor, if your company did not have a patent on the feeder governor you were forced to use one of your competitors or you needed to buy one similar in design as this
The Following User Says Thank You to Glenn Gieszler For This Post:
FM 208 Governor Slowturn Oil Field Engines & Related Equipment 2 01-10-2016 09:26:32 PM
IHC LB 3/5HP governor hitandmissjoe Antique Gas Engine Discussion 4 12-20-2015 08:22:43 AM
Governor help please Frick1909 Steam Stationary Engines, Traction Engines, Steam Boats 11 08-27-2015 11:35:52 AM
If you are in need of Governor help... turbodiesel09 Generators & Electric Motors General Discussion 0 09-04-2010 05:06:55 PM
Oil Governor/Steam Governor Ed Bertschy Steam Stationary Engines, Traction Engines, Steam Boats 2 02-28-2003 10:35:21 AM
