Steam Engines
Boiler Fabrication
this thread has 460 replies and has been viewed 114628 times
Old 11-04-2005, 03:52:03 PM
Default Re: Boiler Fabrication
One of the best ways I've found to remove that caked on/baked on grease on engines is to take a cutting torch, turn off the oxy. and burn it. This hardens it up considerably. Then you can take a wire brush to it and it comes off quite easily. If a torch ain't handy, and it's on a flat surface, take some kerosene, soak a rag in it, and set the rag on fire on top of the grease. Then apply wire brush as before.
Dan, the boiler fab thread has been nothing short of fascinating for me. I had to show a lot of our layout guys here at work what a big burner table looks like. Makes ours look like a miniature!
Mike M
Old 11-05-2005, 11:06:36 AM
Dan Donaldson's Avatar
Dan Donaldson Dan Donaldson is offline
Mike M
Our burning table can hold (6) 8'-0" x 20'-0" plates at one time or many variations there-of. We have burned plates 60’-0” long. It is large enough that the operator can burn parts at one end of the table while helpers load or unload the other end of the table allowing for continuous production. There are two plasma cutting torches (one of which can rotate to cut bevels on the edges of plates for weld prep), two permanently attached oxy-fuel torches, an arc writer (scribes text and layout lines), a zinc marker which can also do layouts and a punch which can locate prick punch marks. We also built an attachment that can hold four more oxy-fuel torches, which we use to rip long plates (up to 60’-0” long) for bridge girder flanges.
This machine is becoming too small for the projects we are building so there are plans to get a bigger machine.
Dan Donaldson
Old 11-07-2005, 05:37:22 PM
John Deck John Deck is offline
Dan I would be curious if you are keeping a log on your time spent on this project and will be doing a cost to see what it would be in the real world to do this kind of work. We talk about this on here every so often but no one has any real time numbers. Would like to know more about how you set up to do this. The pictures are great and reminds me of working in Tom Terning's shop a number of years ago.
Old 11-07-2005, 08:27:32 PM
Scott's Avatar
Scott Scott is offline
What pressure will it be stamped with?
Old 11-08-2005, 01:10:30 PM
I am keeping fairly detailed time sheets. I have the hours broke down by job type i.e. detail drawings, drilling holes, beveling etc... It will be interesting to see how much time I will have been spent when it is done.
Dan Donaldson
Old 11-08-2005, 01:11:15 PM
175 psi.
Dan Donaldson
Old 11-09-2005, 03:54:19 PM
I am in the fortunate position of working for an ASME code shop. Because of my experience at the shop I am familiar with material tracability and what the inspector will be expecting as far as documentation. I also have experience with what is involved with fabricating pressure vessels as far as forming material, what type of weld preparation is required, fit up and match drilling.
I am also fortunate to have meet Jonas Stutzman (J S Company) by chance in 2003 while visiting my girlfriend (now wife) in Ohio. We were driving to an Amish cheese shop when I noticed Jonas' shop off the road. We stopped in and got to talk with Jonas and I was very impressed with his operation of building ASME "S" stamped boilers and engine restoration. He has one of the nicest machine shops I have ever seen. I offered to do detail drawings for the boilers he was building and that is how I got familiar with how fire tube boilers are constructed and how safe they are if they are in good order and operated properly.
If it were not for having the drawing experience and ability, the shop available to do the fabrication and Jonas to do the final assembly and certification I would not even attempt such a task. Doing a large percentage of the work myself is making this project affordable for me.
Dan Donaldson
Old 11-09-2005, 04:35:55 PM
Dan,
Are you going to have it finished in time for the show this weekend at Flywheeler Park, or are you shooting for February?
Jeff Smith
Old 11-10-2005, 12:35:03 AM
Pennerjw Pennerjw is offline
Dan Donaldson
That will be very interesting! I am curious if you could guesstimate the cost, were I to walk into your shop with a handful of blue-prints and say, "Build me one please!".
Old 11-10-2005, 11:00:05 AM
Originally Posted by Jeff Smith
Dan,
Jeff Smith
I'm shooting for February. I'm just not sure which year though.
Dan
3hp associated engine truck number 2 fabrication hopefully uk-keith Antique Gas Engine Discussion 4 12-08-2007 04:45:50 PM
what is the contact info for Oliver boiler and Stutzman boiler? MarkP Steam Stationary Engines, Traction Engines, Steam Boats 4 10-03-2006 07:44:37 AM
Witte head: fabrication or wait RHudson Antique Gas Engine Discussion 2 06-16-2005 09:00:11 AM
magnets/fabrication martin reed Generators & Electric Motors General Discussion 1 05-29-2001 09:04:26 AM
