Copper Line Repair
this thread has 2 replies and has been viewed 799 times
Old 11-01-2017, 07:43:43 PM
Default Copper Line Repair
I wish I had taken a before picture. I bought this IR compressor for 1/2 price, it had been knocked over and mashed a line shut and broke the control box. I removed the line, cut the fins away from the damaged area, heated it dull red to anneal it. I screwed a pipe cap on one end, fittings on the other end to reduce it to 1/8" pipe. I filled it with water and installed a grease zerk, pumped it with grease and the dent came right out, wasn't worried about cosmetics but with a little more time it could have been near perfect.
Name:	line repair.JPG
The Following 10 Users Say Thank You to J.B. Castagnos For This Post:
Old 11-01-2017, 11:30:18 PM
s100 s100 is offline
Default Re: Copper Line Repair
That's a nice looking repair. I've had luck in the past getting dents out of copper tubing by forcing some bearing balls similar in size to the pipe's ID through the pipe. I suppose if I got lucky and the balls were an exact fit I could use grease to push the balls but as a general rule I do not get lucky.
You say you heated the tube to anneal it, but you do not mention quenching the hot metal. I've reused copper head gaskets on British motorcycles and the instruction was always to heat then quench, just the opposite of what you'd do with ferrous metals. I've always gotten a good seal using this approach so I know it works. But once I tried to bend some thin wall copper plumbing pipe and didn't manage to get it to work. I annealed the same way, heat/quench, then to add to it I filled the pipe with sand and plugged the ends. I used a properly sized bender but still the pipe kinked every time.
p.s. Pay close attention to the fittings at the end of the pipe. If it took a big wallop those might be distorted and so leaky. In the past I have had occasional success in restoring the damaged ends by driving a close fitting mandrel with a slight taper into the end of the pipe.
Old 11-02-2017, 04:55:21 AM
A friend used the ball bearing method to straighten a brass pipe manifold on a marine engine. He made a push pipe with a matching flange on one end, a nut on the other. A piece of all thread pushed the proper sized greased balls through, next smaller balls were pushed through. I thought of that for this pipe but it was fairly long with the bend 1/3 of the way. The fittings were used to hold the water and grease, I think they will be OK. Annealing non ferrous metals happens when the temperature is reached, cooling is only for convenience and doesn't affect the results. Ammo re-loaders use a setup with the casings passing a torch and then knocked into water, the water just makes it possible to pick the shells up quickly. Look up annealing non ferrous metals.
The Following 2 Users Say Thank You to J.B. Castagnos For This Post:
Johnson two line single line tank conversion Jamie Darian Brown Antique Marine Engines and Outboard Motors 5 04-27-2015 06:18:51 PM
How to get copper to look old? Gene Fisher Antique Gas Engine Discussion 16 09-08-2013 09:41:36 PM
Copper forging FarmerJohn Blacksmithing and Metallurgy 5 10-28-2012 10:42:19 AM
Where to get small copper fuel line? M Schwab Small Air Cooled Gasoline Engines 24 02-18-2012 01:16:06 AM
copper tank dusty Steam Stationary Engines, Traction Engines, Steam Boats 3 04-05-2004 02:10:45 AM
