United Air-Cooled Need Some Help
this thread has 7 replies and has been viewed 1433 times
Old 01-05-2012, 07:34:16 PM
A Louck A Louck is offline
Default United Air-Cooled Need Some Help
We have what we think is a 1 1/2 HP United. The closest we can find is a pic on page 520 of C.H. Wendel's book. The bore is 4" & the stroke is 5". The nameplate is missing, so we need the HP, Type & a typical serial #. From what I have read, the gooseneck trip was introduced in 1916. That's about all we know. Any help would be appreciated. Thanks--- Al Louck, Oquawka, IL
Name:	United 02 (1-5-12).jpg
ID:	125025   Click image for larger version
Name:	United 03 (1-5-12).jpg
ID:	125026   Click image for larger version
Name:	United 04 (1-5-12).jpg
The Following User Says Thank You to A Louck For This Post:
Old 01-05-2012, 08:18:52 PM
Doug Kimball's Avatar
Images: 78
Default Re: United Air-Cooled Need Some Help
Al,
Here's a catalog cut of a 1 3/4 hp and a couple of a friend's with Webster mag ... also 1 3/4 hp. Your mixer does not look to be United.
ID:	125031   Click image for larger version
ID:	125032   Click image for larger version
ID:	125033   Click image for larger version
In Kennebunk, Maine;
Doug Kimball
Old 01-05-2012, 08:37:38 PM
In many ways, it resembles my air cooled Associated, with the exception of the mixer. Mine's a battery ignition. Trip mechanism is different.
The Following User Says Thank You to Pat Barrett For This Post:
Old 01-05-2012, 09:44:41 PM
Doug & Pat--- Thank you both. Pat, could we see a pic of your Associated? Doug, do you have any serial numbers for us? Also, what does the "Type A" denote? I'll have to admit I'm a little confused with the similarities between United, Associated & Acadia. Al Louck
Old 01-05-2012, 10:00:36 PM
Images: 78
I don't have ser.#'.
I think the biggest difference between Type A & F is the cylinders on A's are bolted to base with vertical bolts; the F's have horizontal bolts.
Doug Kimball
Old 01-07-2012, 03:07:27 AM
Dick Webber Dick Webber is offline
I can't explain the type A except that I think most were of Associated origin. Most type F were Waterloo produced, but I think there is also a type F produced by Thompson which precedes the type A. ????? There is also a type B and C. C were Nelson Bros production and might have been in UK. Type H often appears on dual fuel engines. Type S is a later 6 hp which appears to be an uprated 4 1/2.
The catalog cut of the air cooled is interesting in that it shows an air cooled equipped with a 2 bolt mag. That picture shows the EZV mixer. The J type mixer followed the 2 bolt mag, but not by much. This could be a real late air cooled.
Wish I new more.
Dick
Old 01-07-2012, 10:47:11 AM
OOOPS. It was late. That's not a 2 bolt mag in the catalog cut.
Dick
Old 01-07-2012, 12:20:22 PM
Walt Beeman's Avatar
Walt Beeman Walt Beeman is offline
Here are a couple of pictures of a United mixer and head for a 1 3/4 horse, don't know for sure if they are from an air or hopper cooled engine.
Keep Enjoying Old Iron,
Walt Beeman
United Air Cooled 1 3/4hp Bob Bachman Unidentified Engines 2 02-12-2009 07:48:17 PM
United Air Cooled Paint Scheme Hank Czerwick Antique Gas Engine Discussion 1 09-05-2007 11:09:16 AM
United air cooled John Crofoot Antique Gas Engine Discussion 2 08-12-2007 10:55:56 PM
United Air Cooled Gas Tank Larry Evans Antique Gas Engine Discussion 2 02-11-2007 11:23:50 AM
Air cooled United Frank Brymer Antique Engine Archives 4 04-20-2004 09:33:07 PM
