Hart Parr 12-24 Engine Advice/ Tips
this thread has 10 replies and has been viewed 1617 times
Old 07-29-2012, 10:33:28 PM
poolguy poolguy is offline
Default Hart Parr 12-24 Engine Advice/ Tips
I had the valves ground, new springs, new head gasket,I want to pull the pistons, and clean the rings? yea- nea..? I do not have any money left to do anything more to it right now, just looking for advice on what to do now to help clean it up. Will I break the rings? Should I do anything to the rod ends/crank?? Thanks in advance, Steve
The Following 3 Users Say Thank You to poolguy For This Post:
Old 07-29-2012, 10:45:21 PM
HBurk HBurk is online now
Default Re: 12-24 engine advice/ tips
12-24 what?
Old 07-29-2012, 10:48:57 PM
If compression is good, don't bother rings. Sometimes they can get stuck with unburned carbon. Handle them carefully and if removing, make 4 strips of thin metal with a 90 deg bend at one end to slip under a ring so you can slide it up. Don't spread open too far. Rock the crankshaft and observe play at rod. It should be slight only.
Old 07-29-2012, 10:57:23 PM
Steve,
It really would help if you explained what tractor you are working on. I see you are close by, so I might be of some assistance to you if needed.
Corey
Old 07-30-2012, 07:22:46 PM
Sorry, it is a 1928 Hart Parr 12-24, thanks, Steve
The Following User Says Thank You to poolguy For This Post:
Old 07-30-2012, 08:09:21 PM
If the rings are still loose how much spring is left in them?
A new ring will be open enough that it will barely stay in the groove.
I think if the rings expand enough that it takes a little effort to push them even with the piston grooves I'd leave them alone.
Hart Parrs, having total loss oil systems, are really REALLY forgiving in that department.......
If the rings are stuck I'd paint them every day with brake fluid.
I've used a 50/50 mix of brake fluid and penetrating oil with great success.......
The problem with straight penetrating oils is they dry out while brake fluid doesn't.
A combination of the two aids penetration of the brake fluid and slows down the evaporation rate of the penetrating oil.
Old 07-31-2012, 05:59:41 PM
Geoffrey Mark Geoffrey Mark is offline
be nice to see some pictures off your tractor , i have a 12/24 requireing a bit off work also !
Old 07-31-2012, 09:51:37 PM
Thanks for the replies, I hope to put it back together this week with my valve job...so any other advice is welcomed...
Old 07-31-2012, 09:58:52 PM
Arrow Re: Hart Parr 12-24 Engine Advice/ Tips
Do you have the Hart Parr Lightweight Owner's Manual?
You can download it there >>> http://andersonofrosholt.com/mypics/...structions.pdf
Old 07-31-2012, 11:46:37 PM
Ken Majeski's Avatar
Images: 45
Default Re: Hart Parr 12-24 Engine Advice/ Tips
Check the cotter pins in the governor weights before you run it.
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
Need Data/Drawings For Hart-Parr 60 HP Engine Elden DuRand Antique Gas Engine Discussion 8 10-15-2011 09:39:07 AM
Hart-Parr 28-50 remove engine?? AdamB Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 01-03-2010 11:02:12 PM
Hart Parr 30-60 Engine Instructions Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 04-25-2009 02:22:05 AM
Hart-Parr 36 engine MR.22 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 15 03-22-2008 04:34:46 PM
Hart-Parr-engine weight?? ihorse Antique Engine Archives 2 04-27-2004 08:14:13 AM
