"Tumble" plows
this thread has 24 replies and has been viewed 6481 times
Old 12-03-2013, 11:47:39 PM
LAKnox LAKnox is offline
Default Re: "Tumble" plows
Originally Posted by Steve Welker View Post
Lyle
Here is a picture of a MM 'tumblebug'. I'm not sure of this model, but it is my grandfathers, and I did plow with this plow behind my dad's E27N Fordson about 15 years ago. What a wild piece of mechanical engineering! Pull the one trip rope at the end of the furrow and it looks like the plow is falling apart as it rolls over and raises. Then as you are turning you need to pull the second rope at the right time to swing the hitch to the opposite side, before pulling the first rope again to drop the plow down. Keeps you very busy at the end of a field with a tractor w/o power steering!! The plow is heavy and awkward, but did preform very well.
-Steve
Cool! Nice to see pics of variations of the same thing. Thanks.
Lyle
---------- Post added at 08:47 PM ---------- Previous post was at 08:39 PM ----------
Originally Posted by Marcel P View Post
I think that our Mathis-Moline is a French copy of the MM Tumblebug.
Marcel
Interesting. Our "tumblebugs" were machines we used to build borders. We had 2 different kinds, one that was 2-bladed and 14' wide. We would pull it slowly across the field, that we'd marked with lines every so many feet. The blade would tumble until we locked in, then it would drag and pull up dirt. We'd trip it on top of the marked line and it would roll over, dumping the dirt. This was for alfalfa fields, where we needed a good, solid border for flood irrigation. The other tumblebug we used had 3 blades and we used that on the top end of the fields to rebuild the rows where they met up with the irrigation ditch bank. We'd disk the ends down, then re-buck (another name for this contraption was "row-buck", because it bucks pretty good when you trip it) so we could irrigate again. I sure wish I had pics of all this stuff. :-(
Lyle
Old 12-04-2013, 09:18:32 PM
LandLFarm LandLFarm is offline
[QUOTE=LandLFarm;980400]Lyle,
We have several horse drawn ones as well as a modern IH. Can send pics
if wanted.
LandL Farm
Pics attached
ID:	181117   Click image for larger version
ID:	181118   Click image for larger version
ID:	181119   Click image for larger version
Old 12-05-2013, 12:18:45 AM
[QUOTE=LandLFarm;984786]
Originally Posted by LandLFarm View Post
Lyle,
if wanted.
LandL Farm
Pics attached
Nice pics. First one looks to be a rollover plow for a 3-point. 2nd and 3rd I've actually used behind a horse when I took a horse driving class at UC Davis in the late 70's. The dump rake I used as a kid. We'd pull it behind a Farmall usually, to clean up any loose alfalfa that the baler missed, then fork it up for our small bunch of sheep my granddad kept. :-)
Lyle
The Following User Says Thank You to LAKnox For This Post:
  #24
Old 12-05-2013, 10:30:22 AM
Lyle, Question, how can we post pics of our collection?
Old 12-06-2013, 12:17:37 AM
I'm not sure in the gallery, I know only how to attach pics to posts. Check the FAQs; link at the top of the page.
Lyle
Early Briggs Stratton "Y" with "X" in type number mschreiber Small Air Cooled Gasoline Engines 7 05-14-2012 09:33:34 PM
Rough & Tumble "Time of Harvest" show Oct 14 & 15 Jeff in PA Shows and Swap Meets 3 10-12-2011 08:41:44 PM
Fairbanks-Morse "Z" style "C" 3 HP Dishpan Multi-Fuel David M. Lyon YouTube Old Iron Videos 0 11-09-2010 09:23:11 PM
Union Pacific RailFest 2007- "844" & "3977" Robert M Steam Stationary Engines, Traction Engines 18 10-29-2007 09:05:11 PM
Fairbanks "Jack of all Trades" "T" Ser# List??? Shane Ball Antique Engine Archives 1 07-29-2003 10:37:57 PM
