10-20 McCormick Deering Question
this thread has 14 replies and has been viewed 4344 times
Old 02-24-2012, 07:23:58 PM
Howardh Howardh is offline
Default 10-20 McCormick Deering Question
Hi -
Just wondering if there was such a thing as a 10-20 or W30 McCormick Deering industrial tractor???
A friend of mine ran into a guy claiming there was.
Thanks for any info,
Howard
Old 02-24-2012, 09:35:25 PM
Sam Hamilton's Avatar
Sam Hamilton Sam Hamilton is offline
Default Re: 10-20 McCormick Deering Question
A 10-20 or W30 on steel wheels with solid rubber pads instead of skid rings and lugs, or one on rubber tires with truck treads would be an "industrial" version. There were about 500 15-30s built like this with rubbber tires on 50" rears. Apparently in the late 1930s pneumatic rubber road tires were offered. "Road" tractor might have been the preferred name. I'm pretty sure that the name plates and decals didn't make any specific reference to "industrial" or "road."
Old 02-24-2012, 09:41:46 PM
Ken Majeski's Avatar
There sure was a Industrial 20, lots of them were used on Dump Wagons, Graders ect.
Ken Majeski, Ellsworth Wis.
Old 02-24-2012, 09:59:40 PM
I was about to comment that my IHC serial number list doesn't list any "named" variations except for the "Fairway" versions of several different models. My list doesn't mention the Model 20 and I've never heard of one. That goes to the top of my want list. Fascinating. A Model 20 Industrial would look great sitting next to my Allis IB that I'm about to finish for my wife. Is the Model 20 a modified 10-20? Any idea of any serial number prefixes? Thanks.
Old 02-24-2012, 11:51:46 PM
I have a 1928 Russel Motor Patrol no 4 with a I-20 power unit. It has led a Hard life. I plan on resurecting it with some 10-20 parts. After Caterpillar bought Russel in late 1928 they discontinued the IHC power unit and replaced it with a Cat 20.
The gears are all in the wrong place including reverse and second and third are a Lot faster than the 10-20.
Here is a link to Tractordata.com with some specs, You can click on the transmission link to see the difference in speeds. http://www.tractordata.com/industria...strial-20.html
I've talked to some other people that have other brand graders with the I-20 power unit. Most but not all I-20's used gasoline as far as I know so that explains the higher horsepower figures.
A little more info here http://tractors.wikia.com/wiki/McCor..._20_Industrial
Note that they say 4 speed here. I don't know the exact year they added the 4th speed.
The Following User Says Thank You to Ken Majeski For This Post:
Old 02-25-2012, 11:17:24 AM
Thanks a lot, fellows!! I sure appreciate all the good information!!
Howard
Old 03-05-2012, 09:41:49 PM
Clark Bigger Clark Bigger is offline
I have 2 galion graders with I-20's both 4 speeds '27 and '35
shift pattern is marked L, 2.3. and H, which is a road gear.
the
the other I-20 has large drum brakes and a foot throttle heavier front axle. I think the fuel tank is larger too.
Ben Kinsinger had reprints of the books at one time
serial number prefixs include KC, IND and IN
The Following User Says Thank You to Clark Bigger For This Post:
Old 03-06-2012, 12:37:03 AM
thetractorfreak thetractorfreak is offline
Photo Re: 10-20 McCormick Deering Question
my 1927 i-20
ok last try at the pic, if not its on my profile
Craig here: THAT one Lee? >>> .......
The Following 2 Users Say Thank You to thetractorfreak For This Post:
Old 03-06-2012, 08:23:04 AM
Harry Henderson Harry Henderson is offline
They got all over the world too, this one's in the UK.
The Following 5 Users Say Thank You to Harry Henderson For This Post:
Old 03-06-2012, 09:34:58 PM
Rob Charles Rob Charles is online now
That I-20 looks like is has Fordson wheels on it.Rob
Old 03-06-2012, 10:23:44 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
about 3yrs ago,off Rt-78 20min from Phillipsburg,near Bloomsburg/Silvertown,i had bid on a I-10/20 with a moto-patrol grader blade tractor at an old farm auction..I can remember it was an Arthur Hanna auction he conducted. i stopped bidding at $700 cause i didnt have a long enough trailer to haul it home and was there for a farmall cub that i didnt win anyway... i often wonder if someone local bought that unit I-10/20. wish i had taken pictures that day.. if someone local here in PA/NJ got that unit and is a staker,please get in on this thread.
Old 03-07-2012, 08:39:56 PM
Russ Hamm's Avatar
Russ Hamm Russ Hamm is online now
There were steel wheeled and lugged 10-20 industrials also, a friend had one with rear road wheels and the front axle was 15-30 with same for wheels. That one had a Samson winch on it, could have been oil field use.
International wasn't shy about manufacturing machines for any need.
Old 03-09-2012, 12:05:03 AM
I see on the ads a grader with an I-20, a russel, hand controls..simalar to my galion with hydraulics
---------- Post added at 11:05 PM ---------- Previous post was at 11:02 PM ----------
do fordson & IH have the same splines on the rear axle?
Old 03-09-2012, 12:28:25 AM
wierd as it is ours has the same splined axles and wheels as a fordson, but i have never seen another with splined axles. I was told by the original owners daughter that it was custom ordered.Also all the other I-20's i have seen were gas only but ours is factory distillate, and most others had the individual rear brakes, which ours doesn't. Mine spent its life maintaining RT7 out of south shore KY until it was paved, it then ran a sawmill till the owner died. I am told by numerous people, one day the owner was sick and that another guy was driving the tractor who had never used it and he ended up running it off the edge of an embankment and it killed him. While mechanically restoring it we have found that the steering shaft, brake lever, and shifter have all been broke off and brazed back on along with a huge gash in the trans case and the front axle mount
---------- Post added at 11:28 PM ---------- Previous post was at 11:26 PM ----------
also the steering wheel is a modified valve handle
The Following User Says Thank You to thetractorfreak For This Post:
Old 03-09-2012, 12:52:34 AM
early IHC had the single key, I don't know what year they went to spline. never saw the wheels interchanged before
IHC McCormick Deering LA/LB Question daydk1 Hit & Miss Gas Engine Discussion 10 03-06-2013 06:50:52 PM
McCormick Deering 10-20 question of my own Mike McKnight Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 11-30-2009 11:25:20 AM
McCORMICK-DEERING Vacuum Pump Question Ron Vance Hit & Miss Gas Engine Discussion 1 08-27-2008 06:52:12 PM
McCormick Deering 1 1/2HP joe brosseau Hit & Miss Gas Engine Discussion 4 12-29-2007 06:23:28 PM
Type M McCormick-Deering mixer question Dave16405 Hit & Miss Gas Engine Discussion 4 10-05-2007 10:00:42 PM
