!948 I H Cub
this thread has 2 replies and has been viewed 1234 times
Old 05-10-2012, 04:41:29 PM
David Scott David Scott is offline
Default !948 I H Cub
Quick Question how do I remove the front axle?
David
Old 05-10-2012, 05:58:09 PM
EdDarowski EdDarowski is offline
Default Re: !948 I H Cub
The axle pivots on a pin, in the middle. REMOVE the two bolts, anchoring the pin, to the base of the radiator. Knock the pin out, and the axle will drop put. There should be a washer on each side of the pin housing, on the axle.
Old 05-10-2012, 06:22:23 PM
Thank you I didn't see the washer
