'35 Case L belt pulley
this thread has 4 replies and has been viewed 1506 times
Old 01-31-2014, 07:42:49 PM
Stomper Stomper is offline
Default '35 Case L belt pulley
I have called some older salvage yards in our part of the state and no luck finding a pulley. Is a LA the same? Also, does anyone have one they would let loose of? We were kind of wanting to put it on the thresher this summer. Thank you guys!
Old 01-31-2014, 09:44:11 PM
J Ware J Ware is offline
Default Re: '35 Case L belt pulley
Have you tried Beiwers, give Gary a call, if he don't have it he may know where their is one. And no the LA's are not the same. Jim
The Following User Says Thank You to J Ware For This Post:
Old 02-01-2014, 08:58:24 AM
You might pm me their number. I haven't heardof them. Thank you
Old 02-01-2014, 11:21:54 AM
Phil Johnson's Avatar
Go to the top of the page and click on "sponsors". Their info is on there.
The Following 2 Users Say Thank You to Phil Johnson For This Post:
Old 02-01-2014, 10:08:10 PM
Oldtech Oldtech is offline
No The LA is different. Unless maybe early LA was like the L. The LA had a small hub for the brake.
The Following User Says Thank You to Oldtech For This Post:
What is this belt pulley for? B.L. Rodenkirch Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 12-10-2015 03:12:57 PM
Need flat belt pulley for 1/4 scale Case steam4fun Scale Model Engineering 3 10-16-2008 09:51:44 AM
Flat Belt pulley Buster2 Farm Antiques and Collectibles 5 07-10-2007 12:57:20 PM
PTO belt pulley for 40 JD JHFoster Antique Farm Tractors 2 11-24-2006 02:35:21 PM
Belt Pulley Bill Sherlock Hit & Miss Gas Engine Discussion 0 05-06-2006 12:00:10 AM
