'38 John Deere G - Sleeving the block?
this thread has 3 replies and has been viewed 1547 times
Old 08-11-2014, 07:15:48 PM
61jdgreen 61jdgreen is offline
Default '38 John Deere G - Sleeving the block?
Just got the stuck pistons pushed out and one side is not a pretty sight - some deep pitting, especially ahead of one piston in the combustion area. If boring can't clean this up enough can anyone share an experience with sleeving? Is it even advisable? I know it will be more expensive than just boring. Thanks.
--Jerry
Old 08-11-2014, 07:38:05 PM
PFT's Avatar
PFT PFT is offline
Default Re: '38 John Deere G - Sleeving the block?
Dave Richards - Route 38 Engine Machine Shop in Newark Valley NY sleeved a JD (G I think) block for my brother (Jim). It looked like new when it was done. Jim's customer picked it up to assemble himself, so I don't know if he even has it together yet.
You can contact Dave Richards at: 607-642-5169
PT
Old 08-11-2014, 09:27:01 PM
Tony Rye Tony Rye is offline
been working on eng a long time if a sleeve is installed right you will have know problems wet sleeved and dry sleeved eng have been around a long time . just fine a good mach shop
Old 08-11-2014, 09:28:10 PM
Anything above the top of the piston doesn't matter.
Over size pistons might not be so easy to come by....... .......but it would be a heck of a lot cheaper than sleeving and buying pistons.
John Deere GM Block Damage rogercsi Antique Farm Tractors 3 05-30-2013 02:26:45 PM
John Deere unstyled B block? 55gasser Antique Farm Tractors 1 03-12-2013 11:13:23 PM
1941 B John Deere Block patchen1 Antique Farm Tractors 0 02-18-2013 12:58:28 AM
John Deere unstyled B block? 55gasser Antique Farm Tractors 6 01-31-2013 06:11:07 PM
John Deere B Block che57vy Antique Farm Tractors 3 01-09-2013 07:15:49 PM
