112"-120" wide rear optional tractor axle's
this thread has 3 replies and has been viewed 1137 times
Old 05-26-2015, 11:59:58 PM
TSeaberg TSeaberg is offline
Default 112"-120" wide rear optional tractor axle's
I have seen several existing tractors and pictures in brochures with these real wide rear axles 112"-120" width. Lately I have been wondering what exactly these were needed as an option for? There has been several references to them being vegetable tractors. Does anybody out there have experience with this option and possibly some of the equipment used with these odd tractors?
Old 05-27-2015, 12:53:32 AM
Norm Johnston Norm Johnston is offline
Default Re: 112"-120" wide rear optional tractor axle's
120" or 3 metre track settings are widely used down under here in Australia and is commonly called tram tracking, this is used in conjunction with accurate guidance and the tractor, coltivators, sprayers, seeders, and combines always drive on these tracks with the crops sown in between either in beds or direct into the ground inbetween the 9 metre tracks,
The Following User Says Thank You to Norm Johnston For This Post:
Old 05-27-2015, 11:54:25 AM
We sold a couple of Oliver tractors with extra long axles They had Marbeet sugar beet harvestors mounted on them.
The Following User Says Thank You to John Schwiebert For This Post:
Old 05-28-2015, 08:26:17 PM
LukeSte LukeSte is offline
Yes up here on beets as well. I have seen 2 Ihc 300 tractors with mounted harvesters that have the extension.
24" rear tractor wheel source mag473 Antique Farm Tractors 2 05-25-2015 10:48:33 PM
Very Large Redwood Board 50" Wide, 2" Thick, 16' Long Jon Rozevink Wood Shop and Projects 22 12-18-2014 06:30:17 PM
Rear bolsters ID please "H702X" Kevin O. Pulver Hit & Miss Gas Engine Discussion 4 03-16-2013 11:24:20 PM
Farmall Regular wide front axle Bob McGhee Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 20 03-14-2013 11:19:56 PM
"Disks" in rear wheels on OilPulls Mike S Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 02-10-2010 12:46:43 PM
