*N Ford Carburetor
this thread has 3 replies and has been viewed 924 times
Old 05-03-2017, 03:56:01 AM
Jeff LaCrone Jeff LaCrone is offline
Default *N Ford Carburetor
I just put a kit in the carb on a 8N Ford. You have to leave the choke on and it runs great. It dies when you shut the choke off. Any ideas? Thanks
Old 05-03-2017, 02:50:26 PM
Kris Golden Kris Golden is offline
Default Re: *N Ford Carburetor
Obviously, you aren't getting enough gas so I'm gonna go on my experience and say its your float level. I recently dealt with that very issue on FIL's 9N so that's why I'm leaning that way. The float in those carbs is awful big compared to the size of the bowl itself and the travel is very limited because of that.
Best of luck!!
The Following User Says Thank You to Kris Golden For This Post:
Old 05-03-2017, 10:24:02 PM
ronm ronm is offline
Usually means there's a passage plugged somewhere...did you blow & run wire through every passage & make sure they're open? The main jet passage in the bottom of those carbs is hard to get cleaned out sometimes.
Smokstak member #442
The Following 2 Users Say Thank You to ronm For This Post:
Old 05-03-2017, 11:36:25 PM
I haven't messed with a M/S carb for a while but I seem to recall some of them had an idle needle that was opposite. you screwed it in to richen it and out to lean it. try turning in on the idle mixture and see if it doesn't help
The Following User Says Thank You to slip knot For This Post:
Zenith Carburetor Ford 300 Six Cylinder tima Carburetors, Mixers, Fuel Pumps and fuel delivery 3 02-10-2016 01:42:22 AM
Ford 8N Carburetor Overflowing trying2mow Carburetors, Mixers, Fuel Pumps and fuel delivery 7 01-18-2015 12:11:57 AM
Ford 8N Tractor Carburetor dtakalo Antique Farm Tractors 0 10-09-2014 08:11:04 AM
Ford 640, 1955, carburetor question. JFLingg Antique Farm Tractors 2 09-08-2014 06:12:08 PM
Unusual Model T Ford Carburetor RonB Hit & Miss Gas Engine Discussion 4 04-04-2013 06:19:54 PM
