'39 Case R
this thread has 1 replies and has been viewed 2309 times
Old 08-12-2005, 08:32:20 PM
Scott H's Avatar
Scott H Scott H is offline
Default '39 Case R
We have a '39 Case model R tractor that we would like to paint, and before we do i would like to fine some parts for it. We need the entire air cleaner assembly from the carb right to the air cap. What make and model is it, and did any other case tractors or tractors in general use the same cleaner?. Any help would be greatly appreciated.
Old 08-12-2005, 10:42:11 PM
Glenn Gieszler Glenn Gieszler is offline
Default Re: '39 Case R
Zenith carburetor model 161-7 used after 1937 beginning production
Imperial Brass strainer No191J used beginning 1939 production
Intake pipe and screen cover should be the same as a CC or C or early V series (Shorter), measure ID of pipe
Air intake had different oil bath air cleaner than CC or C look at some early V series engines for possible parts
Waukesha four-cylinder L-head engine
contact Don @ manifold@smig.net
he may have some parts.
1936 Model RC Case Tractor - 175 Years Of Case Albert City Iowa casertractor Antique Farm Tractors 0 01-06-2019 10:59:00 PM
110 Frick bigger than 110 Case,just something to shake up my Case buddies!! Thomas Diehl Steam Stationary Engines, Traction Engines 37 09-14-2015 04:26:13 PM
J.I. Case Expostion – Case Expo markcorson Vintage Construction Equipment 0 07-20-2015 06:02:19 AM
New CASE water/coal tender for 20hp CASE engine Davide L. Steam Stationary Engines, Traction Engines 10 12-05-2011 09:31:41 AM
What would you do if your Non Case engine had a Case smokebox door and ring put on it Casemaker Steam Stationary Engines, Traction Engines 11 08-30-2007 03:47:58 PM
