'57 FORD 950 LP Questions
this thread has 2 replies and has been viewed 2162 times
Old 08-02-2010, 11:57:42 AM
lonegranger lonegranger is offline
Default '57 FORD 950 LP Questions
When I bought the tractor, it ran on vapor only. Vaporizor inoperative (cracked head. no coolant) and vacuum controlled regulator (VCR) was plugged with dirt and lp residue. Just straight 10#? pressure.
I've completely rebuilt engine and a couple of questions:
1. All the VCR parts are in working order - just plugged with dirt and grime. Is it practical to try and salvage my VCR by cleaning the diaphragms in the VCR? How?
Or ...where might I purchase a suitable replacement VCR? Most new are integrated with a carburetor. I'd like to keep the tractor as original as possible and exact replacement parts are rare and dear.
2. Where can one buy Water Pump seals?
Old 08-05-2010, 11:15:38 AM
Dempster Dempster is offline
Default Re: '57 FORD 950 LP Questions
What brand of LP equipment (carb & vaporizer regulator) is on there ? Bendix / Zenith I've seen a lot on Fords and most parts are available through Zenith distributor dealers. Some brands of LP equipment are obsolete bought out by other companies with no service parts available now. Impco and other brands out there can still get parts for yet. The diaphrams, gaskets and seals get old and leak you are dealing with flammable fuel replace them !
http://www.propanecarbs.com/
http://www.impco.ws/
http://www.zenithfuelsystems.com/
---------- Post added at 10:15 AM ---------- Previous post was at 10:06 AM ----------
Also make sure the coolant fittings in engine block and on regulator and your hoses or lines are not clogged full of calcium deposits restricting flow. If so clean them or replace with new ones. Tractor parts outfits should have rebuilt exchange water pumps or kits.
Old 08-07-2010, 07:28:17 PM
K D Redd K D Redd is offline
If your Ford uses the old ENSIGN LP fuel system like my 1966 C-II Gleaner with a Allis-Chalmers G-262 power unit, a Century Vaporizer is the most compatible with the old Ensign system. You will also need a 66EP tapped elbow and a 4H-102E idle control valve when replacing a Ensign vaporizer.
You might also want to talk to Rob at Moulden Supply, 1-800-221-8467
Kent
8N Ford oil Jim Tremble Antique Farm Tractors 4 05-03-2010 04:18:56 PM
Ford 850 Ihorse Antique Farm Tractors 1 09-05-2008 10:40:41 PM
Model T ford questions Sky Antique Autos and Trucks 26 08-08-2008 06:44:32 PM
Ever see a Ford with HBurk Antique Farm Tractors 9 03-16-2008 07:15:56 PM
8N ford Marty Nelson Antique Engine Archives 1 03-18-2004 04:22:17 PM
