'39 Case D Cylinder head problems
this thread has 3 replies and has been viewed 1890 times
Old 06-17-2011, 04:54:34 PM
orange is best orange is best is offline
Default '39 Case D Cylinder head problems
Hello.
I have a 1939 Case "D" that i'm restoring and i'm having a load of bad luck with cylinder heads. The original head was cracked so i managed to find a replacement which i have rebuilt and put on the tractor, only to find that when i filled it with water, there was water seeping out from the one of the cylinder head studs - another crack!
Anyway, i am looking for a replacement. It is an early "D" so therefore has horizontal spark plugs (as opposed to inclined). A model "C" head would be ok as i could modify it to take pressure fed rocker lubrication.
Any help would be much appreciated.
Andy
Old 06-17-2011, 06:44:43 PM
oldtractors's Avatar
Default Re: '39 Case D Cylinder head problems
If it doesn't have to look right, you can put a later D head on it without any problems. You can probably get more HP out of it, but the plugs will be angled.
Jim Evans
Old 06-19-2011, 04:00:22 PM
Kevin Watson Kevin Watson is offline
Hi i have a Case D head in the shed PM me if it is any good to you i dont know what it is like. I am in County Durham i will be going to Cheffins sale in July if that is any good to you.
Old 12-22-2011, 08:36:18 AM
Finally had my Case D running earlier in the week after much heartache with cylinder heads! It runs really well and i'm glad to report that all fluids are staying where they should do!! It Feels good when something goes right for a change!
I'm going to spend a bit more time on it this weekend so hopefully post a photo or two soon.
Andy
The Following User Says Thank You to orange is best For This Post:
161 F head distributor problems OldironPhil Antique Autos and Trucks 8 10-28-2009 11:33:57 PM
United ring/cylinder problems bergrider01 Hit & Miss Gas Engine Discussion 13 05-19-2009 08:53:17 PM
Case problems andy scott Garden Tractors and Mowers 2 02-10-2009 10:55:14 AM
REO cylinder head Mike S Small Air Cooled Gasoline Engines 0 05-25-2006 10:08:10 AM
Cylinder head repair Ed Jablonski Antique Engine Archives 4 08-30-2000 02:02:47 AM
