'29 McCormick Deering 10-20 help needed
this thread has 1 replies and has been viewed 1645 times
Old 07-15-2011, 09:22:51 AM
Tyler Martin Tyler Martin is offline
Smile '29 McCormick Deering 10-20 help needed
Hello,
I have a '29 Mccormick Deering 10-20. I have a few bugs I need help working out.
I have a Bosch (i think E4B) mag. the mag trips at TDC, but when I advance the timing it is going to far. Do I need to change the timing in the Mag, so it fires at TDC, but is timed retarded? Aslo, do you start with timing advanced, or in the middle?
second is the Carb. I put a new needle and seat on it to lessen the fuel bill. but I do not have the jets set right. It seems to have too much fuel with choke on, not enough with the choke off. The screw at the bottom is 2 1/2 turn out. screw on the top is 1/2 turn out. Does this sound right.
Thank you for the help. Tyler
Old 07-15-2011, 10:26:04 AM
Default Re: '29 McCormick Deering 10-20 help needed
Tyler,
They reproduce the instruction manual for the 10-20's, more than likely Jensales has it. Get that and it will show you how to time the mag and also the carb needle settings. Been too long since I adjusted one of the old Ensign carbs, but am thinking it was 1 1/2 turns on one and 2 1/2 turns on the other?
If I remember right (and it's been several years since I worked a lot on IHC's) the mag should be timed TDC with the lever flipped down. There is a hole on the bellhousing where you can shine a light and see the marks, after you get #1 cylinder on compression stroke TDC. Set it right there, fire #1 on the mag and then see where the bolt holes line up on the coupling. Put your bolts there and you should be set. When cranking the tractor by hand after setting the mag like this I think you should have the spark set back about 3/4 of the way or so. It shouldn't be advanced far, or it'll kick back on you!
Mike M
The Following User Says Thank You to Mike McKnight For This Post:
McCormick Deering I-20 industrial friends needed Hoodeleydoo Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 30 01-27-2012 11:15:58 AM
McCormick Deering I 20 / 10-20 info needed Ken Majeski Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 11-01-2010 03:37:11 AM
McCormick Deering help needed Rag Hit & Miss Gas Engine Discussion 16 10-16-2008 08:33:20 PM
McCormick Deering help needed. Jordan Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 06-06-2008 04:04:22 PM
Help Needed McCormick Deering 11/2 hp. John Kaminsky Antique Engine Archives 6 04-23-2003 12:06:51 AM
