Kiki Inline Injection Pump
this thread has 12 replies and has been viewed 12318 times
Old 02-28-2017, 12:22:50 PM
waterman46 waterman46 is offline
Default Re: Kiki Inline Injection Pump
Your description of the work you did on the Kiki pump is really great and many thanks. I have an Onan MDJE with the same Kiki pump and it works fine but has a leak where one or both of the injection valve bodies thread into the pump housing. I have not found any diagram of the pump so I don't know if there is any kind of seal in this location. In the picture you posted I don't see any seal. If there is no seal and I've checked that the valves are really torqued into the housing but it still leaks, do you think I just have to replace the whole pump?
Sorry for the late reply but your post is the best info I've been able to find.
Doug
On my boat in Mexico
Old 02-28-2017, 05:44:45 PM
moteurdelco moteurdelco is offline
between the delivery valve holder and fuel pump body;Oring (small section) is sealing the fuel. remove fuel injector pipes and unscrew each holder (dont loose the spring and delivery valve in the bottom of boat).
The Following User Says Thank You to moteurdelco For This Post:
Old 03-06-2018, 02:31:54 AM
John Deere 123 John Deere 123 is offline
Could someone take out a delivery valve and send/post a pic of the grove in the plunger relative to the barrel port,
Onan DJE with KiKi pump Tim0477 Onan Generators 29 01-19-2014 01:04:28 PM
Diesel Kiki pump parts? krawlr Vintage Diesel and Oil Engines 6 09-02-2012 10:26:34 AM
Adding an inline electric fuel pump D Behnke Antique Autos and Trucks 6 01-02-2011 01:41:35 PM
Injection pump for a DJB 6kw oldiron 1952 Onan Generators 1 09-06-2010 02:07:32 AM
Onan DJE governor woes - Kiki fuel pump mfisher Onan Generators 5 07-08-2008 10:04:10 AM
