4 pole generator winding numbering system
this thread has 2 replies and has been viewed 2356 times
Old 01-01-2006, 12:07:40 AM
Shootist357 Shootist357 is offline
Exclamation 4 pole generator winding numbering system
I have searched the forums, and can't find the info I'm looking for, so here goes...I have a US light power 5.5kw 115 volt 4 pole genset. The unit is electric start via the generator windings. The wires coming out of the case are labeled T1-T2-T3-T4-F1-A1. T1 thru T4 are directly off the brushes. There is a stud screwed into the frame which has T1-T3-F1-A1 all hooked to it. This stud also provides one of my AC "legs" (T1). My other "leg" is comprised of T2 and T4 tied together with T2 being the "leg". I get 115 volts by going across T1 and T2. So my question is this; Is T1 my neutral, and T2 is HOT? This would mean T1 is bonded to ground on the stud? Any help/ideas is appreciated. Shootist
Old 01-01-2006, 04:47:08 AM
ListerDiesel's Avatar
Default Re: 4 pole generator winding numbering system
I have to ask, not being familiar with the make of generator: Is this an AC slipring or DC commutator set? or even both? (AC output and DC starting)
From what you have said, the connection to the frame should be treated as the neutral and T2/T4 the live or 'hot' leg. If you have an earth connection to the set 'frame/ground' this would make sense also.
F1 is probably one end of the field winding, and A1 is the end from the regulator or hand resistance on the panel.
Peter
Old 01-01-2006, 09:22:55 AM
Peter
It is both AC-DC as you described with the DC commutator start. A1 I have no clue on. It is actually 2 wires hooked together and tagged A1. I see no regulation methods, or any resistors in the head. This is a very old well built unit. The only electronics I've found are 4 large capacitors, one for each set of brushes. HAPPY NEW YEAR !!!! Shootist
Kohler 15RMY62 Generator Winding Issue NH Sparky Kohler Generators 14 01-01-2018 03:22:57 PM
Onan Generator Pole Question Onan Dan Onan Generators 58 03-10-2015 09:31:55 PM
Generator Winding failure ProudDad2005 Generac Generators (SEARS, etc.) 14 10-16-2012 08:32:48 PM
generator winding insulation question jamie10017 Onan Generators 8 04-29-2012 11:46:32 AM
Onan 15.0 JC-99R Generator Winding Question grif Onan Generators 29 04-18-2012 02:19:57 PM
