Help re Delco Light
this thread has 1 replies and has been viewed 1831 times
Old 07-09-2008, 12:58:30 PM
s2airflow s2airflow is offline
Default Help re Delco Light
I have had a Delco Light Model 4 B 12 in the barn for years which I was given by a military vehicle enthusiast.It has a 60 amp ammeter on it & I have only just got it running.I had to fire it up using a 12v battery although it has a pulley on it for a cord pull start-using the cord without a battery doesn't produce a spark.Can anyone tell me what I have?Its 4 stroke side valve.Rectangular tank fitted over the generator,no engine mfr visible,very crude needle valve carb.,again no mfr.,with a very long induction tube passing over the cyl. head and a screwdriver operated butterfly valve adjacent to the cyl. head. about 10" from the carb.Its missing its air filter/throttle governor.Is it WW2 & what would it be used for?Does anyone have a handbook for it so that I know what's missing.Regards,Dave
Old 07-12-2008, 12:00:09 AM
Default Re: Help re Delco Light
s2airflow;
I have what you need. Click on my name and you will get a drop down with some options. You can PM me or use the e-mail option, either way I'll get your message. I sent you an e-mail, but maybe it didn't make it across all that sea water.
I think your correct about the WW II thing. I have some literature that shows one in a remote area with some airplanes in a grove of palm trees. It's far sure WW II airplanes. The smaller "Little Joe" was used in tanks during the war.
"DELCO DON" Southern Illinois
Delco light 752 & 600 Randy DiNarda Generators & Electric Motors General Discussion 5 08-29-2014 09:01:07 PM
delco light brian baker Antique Engine Archives 1 06-02-2004 11:20:19 PM
Delco Light Don Wiebe Delco and other Low Voltage DC Light Plants 0 06-12-2003 11:35:19 AM
Delco Light Don Wiebe Delco and other Low Voltage DC Light Plants 1 06-08-2003 01:24:33 PM
Delco Light Bill Garman Antique Engine Archives 0 01-17-2000 01:17:23 AM
