onan transfer switch
this thread has 5 replies and has been viewed 1833 times
Old 02-06-2013, 09:17:23 AM
bswalsh55 bswalsh55 is offline
Default onan transfer switch
I have a model # OTUDD225-4/120/C transfer switch that will not engage in auto mode when power is lost. The linear actuator shutters , so its receiving a signal, but will not fully throw unless helped manually. Can the actuator be removed and cleaned, lubricated, etc to help or does it need to be replaced?
The actuator is a - Innovey inc. # A02-12-02.
Please help!!
Old 02-06-2013, 09:56:29 AM
Billy J Shafer's Avatar
Default Re: onan transfer switch
Need your full model and serial number.
Could be several reasons for the problem.They did have a problem with some motors getting out of alignment. You should be able transfer it with one finger on the arms. It should slide that easy. I would kill the power to it. Then try moving it. That is a short duration motor so don't let the power stay on to long. It will burn up.
There could also be a problem with the micro switches or the breaker for the motor.Post an email address someone will send you a service manual.
Yes you can remove and clean it. Don't grease it.
Old 02-06-2013, 02:03:21 PM
Thanks for the response, email address is- b.walsh@walshandsons.com\
model # -OTUDD225-4/120/c
S/N - I790447332
actuator part # A02-12-02
It takes a lot of force to manually throw the actuator arm , simalar to a large 3 pole main breaker.
Old 02-06-2013, 07:38:58 PM
I sent the OT service manual.
The Following User Says Thank You to Max Thompson For This Post:
Old 02-07-2013, 09:27:06 AM
Do you have access to pages 42- 46 , checking and replacing of linear actuator? Takes alot of force to switch in the manual mode, power is on when I try this. Would that have an impact? Previous post states it should move with ease, not so with this, almost takes 2 hands.
Old 02-07-2013, 10:00:53 AM
Don't do that with power on. It can break your wrist. You are fighting the motor and you will lose. Turn the power off to move it. There should be a motor disconnect switch in place. Turn it off. It is possible that the plastic guide for the transfer rod is melted.
Onan transfer switch wiring help jluciano719 Onan Generators 7 11-19-2012 04:48:32 PM
Transfer Switch for my Onan BigBlockChev Onan Generators 6 03-08-2012 04:19:38 PM
Help on Onan OT Transfer Switch hoghunter69 Onan Generators 11 12-07-2011 08:25:19 PM
Value of 60 amp Onan Transfer Switch Danile Onan Generators 2 03-05-2011 05:32:04 PM
Onan Transfer Switch don-mar Onan Generators 1 07-16-2009 11:42:06 PM
