Building a "Mount" for the Onan Power Plant
this thread has 259 replies and has been viewed 9178 times
Old 09-01-2017, 09:00:24 PM
JoeE. JoeE. is offline
Default Building a "Mount" for the Onan Power Plant
I got the machine all cleaned up. Going to start reassembling it soon.
I got to thinking after reading all these posts, I remember someone commenting that "if you're going to mount one of these, do it right and get it up off the ground a ways to ease maintenance".
I had been brainstorming of ways to do that without causing myself much work. I wanted it to be something neat looking and useful at the same time.
I didn't want to buy a bunch of raw material to build a square/rectangular tubing frame.. too tight for that.
I have lots of stuff laying around.. "never throw anything away"... that's my mantra.
I was outside my shop looking at something when I spotted this pretty hefty thing that had been laying there for probably 15 years. It was the remains of a big "spot welder" that another person had robbed the welder from.
I had also been thinking that I needed a fuel tank if I decide, or am only able, to run this off gasoline. I had 3 different reservoirs that would work for this... two held diesel, and one held hydraulic fluid... came off a big machine they scrapped at the place I worked. I saved them about 5 years ago.... they been setting all this time, covered with the filler caps on them... no rust.
Anyhow... I drug that spot welder frame in the shop. Drug the smallest of the 3 "fuel tanks" in there, too. The gods must be smiling on me, because the fuel tank dimensions were the exact inside dimensions of the spot welder frame.
I torched off about 5 inches of frame, torched out some stuff that was inside the frame to open it up... picked the tank up with the overhead hoist and it just slid down into the frame at a snug fit.
Then, I picked up the generator and let it down on a pair of boards just setting on top of the welder frame.
That's how it's going to look. Now, I can change the oil and work on it without kneeling down on the ground.
Best idea since sliced bread!
ID:	290085   Click image for larger version
The Following 7 Users Say Thank You to JoeE. For This Post:
Old 09-01-2017, 09:45:01 PM
Default Re: Building a "mount" for the power plant~ Onan JB
That will be a real nice set up!!!!!
Old 09-01-2017, 09:52:48 PM
Glenn Ayers Glenn Ayers is offline
Yep ... get em up off the ground ... so it's a pleasure to service / work on em !
ID:	290090   Click image for larger version
"I'll have the Red Pill, thank you."
The Following 4 Users Say Thank You to Glenn Ayers For This Post:
Old 09-01-2017, 10:48:38 PM
Your kubota is now a high boy.. I like it.. bending over, getting on the floor to get in those is a pita
Old 09-01-2017, 10:51:38 PM
len k len k is online now
I "temporarily" put my 7NHM outside. Got about 12 cement blocks and stacked them ~3 high on all 4 corners. Then put one piece of solid 1 inch thick plywood over them and gen just sits on top , stays there by only gravity, has not moved an inch. All covered with a thick double tarp ( air mattress). Thinking of putting a 100 pound propane tank under it for a gasoline tank.
My JB is still covered up on a trailer. Nice working with it up on the trailer, much better than hurting your knees on the ground. Can stand or sit my butt on a milk crate while working on it.
Only issue with putting them up too high is center of gravity is high, have to make sure they don't tip over.
Also I like your idea of putting the gas tank under gen, saves wasted space.
Old 09-02-2017, 06:28:50 AM
Gunny Gunny is offline
Looks good to me.
Old 09-02-2017, 08:05:46 AM
JohnnyC JohnnyC is online now
.... I thought I was the only one that had a high-boy.... Seriously, it is a pleasure to get them off the ground to service and paint. Below are 2 pictures of my high-boy used during the restoration of my 4.0BFA.
JohnnyC
New Jersey
ID:	290104   Click image for larger version
The Following 2 Users Say Thank You to JohnnyC For This Post:
Old 09-02-2017, 12:44:56 PM
Highboy..... Good access for painting.
But for running: center of gravity looks high, tipsy ( ratio of: height to base width is high). If use gen on highboy, I'ld recommend adding weight to bottom, ( heavy bats, fuel ), to lower center of gravity to make it less likely to tip over when a wheel snags during moving.
Old 09-02-2017, 03:11:13 PM
Vanman Vanman is offline
Or in case it encounters a short circuit while running at speed....
Old 09-02-2017, 03:57:49 PM
Handyhiker1 Handyhiker1 is offline
JohnnyC
New Jersey
That looks like it would be a lot easier to work on then the way I am doing mine. Mine is only off the floor about 20"
Onan 10 CW Power Plant Bumbalawski Onan Generators 20 11-01-2017 11:03:53 PM
Onan J series power plant setup robertbennet Onan Generators 13 09-23-2016 06:11:07 PM
Onan Power Plant SmithBT Antique Gas Engine Discussion 0 12-20-2005 12:30:26 AM
4 cylinder Onan Power Plant- Randy Onan Generators 5 02-13-2005 01:56:29 AM
Onan Power Plant snocat Onan Generators 2 06-25-2004 10:08:25 PM
