Building a "Mount" for the Onan Power Plant
this thread has 253 replies and has been viewed 7995 times
Old 10-08-2017, 04:33:46 PM
JoeE. JoeE. is offline
Default Well, looking here...😂
Right out of the operators manual.
"A permanent installation needs a sturdy, level, mounting base of concrete, heavy wood or structural steel at least 12 inches high to aid oil changing and operating."
I have been vindicated, LOL.
Old 10-25-2017, 12:38:17 AM
Default Possible magneciter issue? No AC and no battery charge.
Things took a turn for the worse today. Prepare for long story.
I had the machine running fine, had a industrial sized resistance type electric heater connected across the line... 10 amps each leg. The battery was getting about 5 amps charge on the meter. This particular battery is not the one I was going to run the unit on... but one I had in the shop running something else.
So, with it behaving as it should, I got around to making a mount to hold the (different) battery I picked out to run the unit with. This is a threaded post battery. Got the mount finished and battery installed, then a nice, heavy duty battery disconnect switch... then made the needed battery cables and attached them to the starter, the aforementioned switch, and the battery.
Bad part was, I didn't notice I had the pos. and neg. cables on the wrong battery terminals. The disconnect switch was in the off position.
So, ready to see my handiwork, I twist the switch on and connect the battery to the system.
I noticed the amp meter needle immediately went to discharge. I thought "WTF" is going on here... didn't even occur to me that I had the battery hooked up backwards.
Anyhow, start the engine (start and ran perfectly) and the amp gauge needle immediately pegged out in the charge direction!!!
I shut the engine down. Thought maybe it would fix itself magically by me standing there staring at it for a second or two, and so I started it back up. It run fine, but the needle did the same thing. I thought, oh well, that old battery is probably really discharged and it takes a lot of charge to get it back up to par. I knew that these are set up to only charge a certain rate, but thought what the heck....
I have that big electric heater load connected to the system all this time... and it was making heat... the big cal-rod elements were turning red. I ran it for about 2 minutes, admiring my work....
All this time, the meter is pegged charging. I walked up behind the generator and noticed that the charging system resistor is glowing red on it's top 1/3rd... even with the fan blowing the heat away!
I ran around and shut the engine off.
I was still thinking that maybe this battery was really drained.... been setting for months in a machine... and that the system was just really working hard recharging it...
But, I thought I should probably test that theory by disconnecting the onboard battery and running off the other battery that everything acted right on.
Ok, hook it up to original battery, flipped disconnect switch back to "on"... needle on amp meter stays at "0".... great!!! Start engine... needle goes to a little below 5 amps charge!!! GREAT again. Everything works good.
I'm thinking... "hmm, wonder if something wrong with this new battery.... about the time I notice the barely visible + and - marks on the battery didn't match the red and black cables I was connecting to them!!! Oh, shit!!!
Got them connected correctly, started the engine back up and it ran and charged and made AC electricity like a champ.
Shut it down and went to work on mounting electrical disconnect switch and 240vac receptacles. It got late and I went in the house.
This morning, I finished the switch wiring, connected a load to see if that was going to work.
Engine starts right up... but the amp meter doesn't move. The load isn't getting any power, either... test it with a Simpson VM and nothing. It was working good when I shut it off the day before!
Get the book out.. thinking I may have fried something in the charging or generating wiring... and went to work troubleshooting.
Tested the previously red hot charging system resistor... 2 ohms... it's according to specs. The wire that's part of that circuit, from the terminal strip up in the control box, and everything connected to it that I could trace... OK.
Take the end bell of the generator... don't smell burnt wiring. No obvious burnt objects or connections, which I feel is a good sign.
I unbolt and swing out the magneciter apparatus to get to the slip rings and brushes.... get the brushes loose and check for shorts or opens in the rotor... it's all ok and the rotor windings are the correct resistance. Brushes and slip ring surfaces look good, too. I don't check the stator windings as of yet.
Start reading about what to do to check the magneciter itself, and my eyes start to glaze over .
I don't want to disconnect too much stuff and end up with bad connections later on.
I'm setting there wiggling wires and see nothing obvious wrong on the outside of the magneciter or the terminal strip, so I stick my fingers in the recess in the rear of the unit to wipe off some dust I see inside there... when lo and behold... I find a wire broken away from a diode!!!!! See attached photos....
I can't tell (as of now) by the schematic (drawing 625A631) for this 04SX1N3B exciter exactly what this diode does, but the broken wire left the diode and went to terminal "35", and the wire from the diode stud attaches to terminal "E2", if that tell you anything.
The numbers on the diode are 80015, and 7242. The diode symbol shows the stud to be the Anode, pin to be Cathode.
A search shows them for sale on ebay.. with not much description.
Can't get Mouser or Digikey to show me anything.. probably aren't doing something right on their search.
Anyhow, I hope this is what has the machine making absolutely NO electricity... and that I haven't damaged the Magneciter....
ID:	294294   Click image for larger version
ID:	294295   Click image for larger version
ID:	294296   Click image for larger version
Old 10-25-2017, 12:46:14 AM
Default Re: Possible magneciter issue? No AC and no battery charge.
Also, left out that I "flashed" the system according to instructions in the manual... with 6vdc to f1 and f2.... Simpson meter connected to E1 and E2... no deflection of the needle at all.
Old 10-25-2017, 02:05:39 AM
Leon N. Leon N. is offline
Oh to read this is painful. I feel sorry for you. Mistakes do happen. Tomorrow Or later today, I will review the Magneciter diagrams to see what was damaged. Sounds like the exciter has been damaged. Terminal 35 is the automatic field flashing positive 12 volt line from the starting solenoid inside the control box. E1 & E2 are the AC power source from the stator to the exciter. F1 & F2 are the DC power from the exciter to the rotor via the slip rings, if I am not mistaken. How that diode terminal became disconnected is a ? Was it so hot it melted the soldered connection?
Did any magic smoke come out? What is the factory build spec letter of your machine? That way we can review the proper wiring diagram and trace out the circuits. Do you have the generator neutral tied to the chassis?
Too sleepy to go further. More later. Note, must confirm, but your Magneciter may have a separate stator winding that charges the battery via a 1/2 wave AC to DC diode in series with that charging resistor which sits in the generator hot air exhaust. Isthat the resistor that glowed red hot? Ouch this is painfull.
  #35
Old 10-25-2017, 12:05:31 PM
I do not pretend to be an authority on the Magneciter. As an electrical engineer I am merely interested in then seeing I have one. I would say the Magneciter I think the owner has employs a separate stator winding to charge the battery. With the battery polarity reversed, the charging system is working into essentially a short circuit. This could have damaged th a stator winding which is separate from the normal 120/240 volts output windings.
There is no way that wire could become disconnected from the diode in question unless it was overheated due to perhaps a short circuit current flow. More analysis later today.
Old 10-25-2017, 12:39:41 PM
Jim McIntyre's Avatar
Originally Posted by Leon N. View Post
...There is no way that wire could become disconnected from the diode in question unless it was overheated due to perhaps a short circuit current flow. More analysis later today.
It's even worse than a 'short' circuit as far as the fault current goes because the polarity of the battery was swapped, putting a huge total voltage across the current limiting resistor. So, yes it's pretty likely the diode also overheated, and self-destructed.
Why no AC though? Hopefully, it's all in the DC flash circuitry and the magneciter, field and stator are OK...
Old 10-25-2017, 01:41:32 PM
Default Re: Building a "mount" for the Onan Power Plant
Do we have a good magneciter schematic for this unit (?), because this is rather curious.. The diode might still be good, wouldn't surprise me one bit.. If it tests OK, I would solder that wire back on and give it a go. Most digital meters have a diode function that indicates the breakdown voltage, or use your old analog Simpson on X100 or x1k resistance range, across the diode (battery disconnected) - couple hundred Ohms forward biased (black probe on the cathode, red on the anode), infinite/open reverse-biased (red probe on the cathode).
Old 10-25-2017, 02:09:56 PM
Jim I agree. Not a huge total voltage but a huge total current back through the stator charging winding. Hopefully it did not damage either that charging stator winding or the resistor that glowed red hot.
As for the exciter I think by looking at 625A631 and knowing that terminal E2 is normally chassis ground but now has a positive 12 volts put on it WRT terminal 35 (the flashing terminal) just trace the path back. He applied positive battery voltage on E2 (normally at ground potential) back through, rectifier # 5, then to the slip rings (F1 to F2) up through the toroid to E1? Not sure, got to think about it a bit more, but I think rectifier item #5 is damaged due to + 12 volts being applied to terminal E2.
He will be very lucky if that is his only problem. I think his exciter may be toast.. More later.
Old 10-25-2017, 02:28:34 PM
I'm still trying to get my head wrapped around the fact the starter worked OK with the fact the battery was hooked up backwards?
The Following User Says Thank You to nothingbutdarts For This Post:
  #40
Old 10-25-2017, 02:43:42 PM
Default Jb 3cr 8389 t
I did test the diode this morning... it still operates correctly.... needle deflection one way, none the other.
The pin is broke clean in half... the exposed surface of the pin isn't black, but shiny copper... it looks to have a hollow center, or maybe there was a defect, or the electrical problem burnt it in half, I don't know.
Going back to the action that caused all this, the plant DID run and produce AC and charge the battery AFTER I corrected the issue...
I ran it with a load then, and ran it without a load later.... nothing connected to the output...when I took it to the muffler shop to show the guy how loud it was. I don't know what the charging system was doing out at his shop.. didn't look at the meter.
I'm hoping that either A). vibrational stress caused it to break off, or B). The reversed battery fiasco caused some over current, which melted this piece in two and spared any other components.
I have a good friend in town who is quite the electronics technician, among a lot of other things... I'm going to his shop to see if he's got one of these diodes in stock.
I don't quite see on the schematic I indicated in the other post exactly where this diode is located, and I don't see anyting on the parts list on that schematic that calls out exactly the properties of the diode.
Maybe my buddy will know... it's not rocket science...
Onan 10 CW Power Plant Bumbalawski Onan Generators 20 11-01-2017 11:03:53 PM
Onan J series power plant setup robertbennet Onan Generators 13 09-23-2016 06:11:07 PM
Onan Power Plant SmithBT Antique Gas Engine Discussion 0 12-20-2005 12:30:26 AM
4 cylinder Onan Power Plant- Randy Onan Generators 5 02-13-2005 01:56:29 AM
Onan Power Plant snocat Onan Generators 2 06-25-2004 10:08:25 PM
