Worthington Blue Brute 85 tow behind air compressor - HELP!
this thread has 13 replies and has been viewed 1405 times
Old 09-25-2017, 04:44:56 PM
Larryt043 Larryt043 is offline
Default Worthington Blue Brute 85 tow behind air compressor - HELP!
Hi, we just bought a tow behind air compressor for an event we have coming up fast, and although I have it running and producing air I have a few issues/questions. The engine oil (4 cylinder International) was clean and full. The compressor side very black and seemed to be fairly low. Unfortunately there is no sight glass or dipstick so I am not sure where "full" really is. The instructions on the machine say to use either 10w40 or SAE 30 oil in the compressor. I have no manual and have not been able to find one. Worthington has not responded to my questions so I am out of luck there too. I drained the old oil out (about a gallon) however I have ready that some of these compressors take up to 5 gallons of oil. There is a filler neck to fill the oil about a third of the way up the compressor. I am not sure if this requires oil to be filled to the neck where it is visible? That would likely be about 3 - 4 gallons. When I did run it with the old oil in it, it seemed to blow a bit of oil out of the air line, and the air also got pretty hot. Not sure if it matters but the outside temp. here now is about 90 degrees. The compressor is an 85cfm Mono Rotor and from roughly the 1970's. Any help on what the oil capacity of the compressor side of this might be would be greatly appreciated. Thank you
Old 09-25-2017, 04:50:17 PM
Default Re: Worthington Blue Brute 85 tow behind air compressor - HELP!
I have a buddy that has been fixing those kind of compressors since the 70s.. but he is on vacation and may be hard to get ahold of him.. and he won't have his books with him but will ask if I can as I have no idea..
Old 09-25-2017, 05:22:40 PM
Gunny Gunny is offline
Onan air compressor?
The Following User Says Thank You to Gunny For This Post:
Old 09-25-2017, 05:33:50 PM
Billy J Shafer's Avatar
I looked it up. Big trailer mounted unit found the manuals for it. But none will give you the specs. Unless you spend 60.00 dollars.
Old 09-25-2017, 05:46:31 PM
No, not Onan. And I am not sure how I posted this under Onan Generators. It is a Worthington Blue Brute 85 Mono Rotor
Old 09-25-2017, 11:00:32 PM
Larry this site has been doing some strange things today.
Old 09-25-2017, 11:22:43 PM
AngrySailor AngrySailor is online now
Is this a screw compressor? Does it have a separator chamber? If so remove elements and inspect/clean/replace them, inspect the separator chamber looking for a drain at the bottom which normally leads to a line outside this housing, remove that lines fitting from the casting and you should find a mesh screen behind it. Clean all these passages of rust and scummy oil. These compressors have the oil sump at roughly air delivery pressure and use differential pressure to lube, there is no oil pump. Oil is fed into the screw inlet to lube and seal, then removed from the air flow by the separator and returned to the sump. They do take LOTS of oil, and almost can't have too much based on the units I've worked on.
The Following User Says Thank You to AngrySailor For This Post:
Old 09-26-2017, 05:31:35 AM
Troll's Avatar
Troll Troll is offline
I have a "Blue Brute" 250cfm screw compressor and it's much the same. I'm thinking it takes 11 gallons of oil but that may include the engine also. I've not serviced it myself but will be later in the year.
The Following User Says Thank You to Troll For This Post:
Old 09-26-2017, 06:56:31 AM
Yes, it is a screw compressor. The oil lines had been leaking so I believe it was low on oil. Only about a gallon in it when I drained it. The refill tube is below center and is an elbow with a cap. It appears as though filling it to this point makes sense since filling it any more would be almost impossible unless you pressure filled it. Currently we have 4 gallons in it, but still not at the full point and I am afraid to run it until I feel a bit more confident. When we ran it (testing before we bought it) it did produce air, but seemed to heat up the oil lines pretty fast but I am guessing that could have been due to low oil. It did have rust in the fuel tank but I resolved that issue yesterday. Engine is fine, just concerned about the compressor side. Thanks all for your input, I appreciate it.
Old 09-26-2017, 10:14:22 AM
Is there a sight glass (more of a window really) on the top of the reservoir? If there is look down through it and there should be a fixed "dip stick" in there with a level marking on it. You can't have a removable dip stick as the oil sump is pressurized. Usually I fill them up, then check theough the window running to see how much more to add. Bleed the sump pressure EVERY time before attempting to open the sump or things get messy (don't ask how I know). These things make heat like crazy and the oil cooler must be clean and all fans working or you will smoke it!
Also I've only ever used synthetic compressor oil in these so I'm not sure how SAE30 will hol up. They do darken synthetic oil pretty quick and in my experience are expensive to maintain to manufacturers PM schedule... 5 gallons of oil, separator maintenance kit for ours was almost 1000 American shekels and was to be changed every 750 hrs Im glad someone else was paying for it!
Also please understand that this is general info, not specific to YOUR make/model...
Vintage Worthington Air Compressor - help Firewoodguy Antique Gas Engine Discussion 1 04-13-2017 07:38:06 PM
old Worthington air compressor ronny p 148 Farm + Industrial Antiques and Collectibles 9 02-28-2016 01:23:27 AM
Worthington Air Compressor jaf3491 Farm + Industrial Antiques and Collectibles 0 04-23-2015 11:31:13 PM
Worthington 6x5 Reciprocating Compressor dkamp Machine Shop and Tool Talk 10 05-21-2014 03:16:43 PM
Worthington air compressor grub54891 Generators & Electric Motors General Discussion 2 08-26-2009 11:39:28 AM
