1979 Onan 10CW Generator
this thread has 22 replies and has been viewed 1139 times
Old 10-14-2017, 10:45:55 AM
consolenut consolenut is offline
Default 1979 Onan 10CW Generator
Posted locally is a 10cw from 1979. Its unfortunately trailer mounted. Owner claims it runs perfect but the picture of the electrical box is a mess. Ive seen a few threads that parts are hard to find. Anyone know the dimensions of this generator and its approx weight? The few ive seen on you tube etc are all proapane or CNG. Did they make a gasoline model. Any ideas or thoughts gladly appreciated. Owner asking $400 for running unit.
Old 10-14-2017, 11:13:24 AM
Default Re: 1979 Onan 10cw Generator
Pics of generator. It is conformed gas
Old 10-14-2017, 11:17:35 AM
Billy J Shafer's Avatar
Can't be from 1979. I went to work at Onan in 1980. They were long gone by then.
Old 10-14-2017, 11:24:42 AM
oh wow 800 pounds. Don't have anything to move it. I figured it was older then 79 based on appearence. It may have been a typo as well.
Old 10-14-2017, 12:16:13 PM
Motorhead's Avatar
They love fuel! Not a real efficient machine but if taken care of will run until the "Second Coming"
The Control panel
and gauges of my
7.5JB
Old 10-14-2017, 12:31:03 PM
Gas hog not really a huge concern. Anyone know the amp output on 110V. Ive looked but no specs really anywhere. 10kw @ 110V is in theory 83 amps. I have a 5000 marquis but looking for more output.
Old 10-14-2017, 02:47:37 PM
With age and everything else. I would guess around 80 amps.
Old 10-17-2017, 01:01:11 PM
It loooks to be in an enclosure or cabinet. Did any CW come this way from Onan? It has a lid that open from the side. To access the top of the engine. Looks kind of similiar to the way the old Lincoln welders are in there enclosures.
Old 10-17-2017, 05:53:39 PM
Kell1961 Kell1961 is offline
On a single phase unit the system will produce 4.1 amps per KW at 240 volts or twice that at 120volts. This is true of any sigle phase set. Wether or not the engine can produce the needed horse power is another question. lol
Old 10-20-2017, 09:23:15 PM
Default Re: 1979 Onan 10CW Generator
finally got the id tag picture curioys is anyonw knows the year and any other info
Serial number 668543779
GEN DATA NO. 10CW3015
Appears to be a single phase only machine
The tag is not to legible. Those are numbers i can decipher. It appears its 87 amps @ 115V. And 43 @ 220V
finally got the id tag picture curious if anyone knows the year and any other info
1979 3W091A Dayton/Onan generator internal wiring question archangel Onan Generators 11 04-07-2016 08:38:20 AM
Onan 10CW 3R/1L generator isodine Onan Generators 6 12-01-2014 12:19:17 AM
Onan 10CW-R generator info? James Lee Onan Generators 7 11-09-2007 04:39:26 PM
Onan 10CW 3R generator Dean C Onan Generators 3 11-09-2007 10:55:01 AM
onan generator 10cw Paul Merrell Onan Generators 2 09-21-2005 12:43:18 AM
