1979 Onan 10CW Generator
this thread has 22 replies and has been viewed 1180 times
Old 10-20-2017, 10:31:03 PM
Motorhead's Avatar
Default Re: 1979 Onan 10CW Generator
Look carefully at the serial number 668543779 and see if the third digit isn't a letter "B". I may be wrong but if it is a letter "B" instead of the number "8" then the set was built June of 1956.
The Control panel
and gauges of my
7.5JB
Old 10-20-2017, 10:32:13 PM
MBB MBB is offline
June of 68 Do you have the model number or did you post it previously? Thats wierd I adjusted my post to read is there a (.) or letter because that changes the serial.
The Following User Says Thank You to MBB For This Post:
Old 10-20-2017, 10:38:53 PM
consolenut consolenut is offline
Its not legible. Can barely read it
Model and spec no
10cw 3B. 6630
Maybe very difficult to read.
Old 10-20-2017, 11:48:25 PM
MBB MBB is offline
Here is close as I can find though I dont believe it is the one because of the Engine Data Code. They are not the same.
Old 10-20-2017, 11:51:34 PM
MBB MBB is offline
It should look something like this. 10CW-3M/663B
Old 10-21-2017, 12:02:15 AM
Here is a pic of the tag. Its barely legible.
Old 10-21-2017, 12:19:27 AM
Motorhead's Avatar
The third symbol looks like a "B". "B" is 1950's so my interpretation is "B" equals 1950's and the 6 just ahead of the "B" adds to 1950 and comes up with 1956. The first 6 is the 6th month or June.
The Control panel
and gauges of my
7.5JB
Old 10-21-2017, 07:20:48 AM
MBB MBB is offline
Motorhead I believe you are correct. It looks to read 3R/663C or 6630. A little black shoe polish may enhance it enough to read it better. Either way this is as close as I can get with a build sheet.
Ok I enhanced the picture just enough to read it. It should be 10CW-3R/663C the serial # 66B543379
Actually the picture looked better on my computer.
Old 10-21-2017, 09:08:59 AM
Billy J Shafer's Avatar
I agree 1956 model.
Old 10-21-2017, 11:54:41 AM
87 amps total. Thats 43 amps roughly per leg. And two legs in this unit correct. If that is the case. That is much better the 20 amps roughly per leg i have now. Ill use it to power my RV in power outages etc. Among other things.
1979 3W091A Dayton/Onan generator internal wiring question archangel Onan Generators 11 04-07-2016 08:38:20 AM
Onan 10CW 3R/1L generator isodine Onan Generators 6 12-01-2014 12:19:17 AM
Onan 10CW-R generator info? James Lee Onan Generators 7 11-09-2007 04:39:26 PM
Onan 10CW 3R generator Dean C Onan Generators 3 11-09-2007 10:55:01 AM
onan generator 10cw Paul Merrell Onan Generators 2 09-21-2005 12:43:18 AM
