Onan 7.5 JB Information Monitoring Panel
this thread has 24 replies and has been viewed 952 times
Old 11-10-2017, 08:56:47 AM
EICBob EICBob is offline
Default Re: Onan 7.5 JB Information Monitoring Panel
Thank you Jack!
-Bob
Old 11-10-2017, 10:22:26 AM
Handyhiker1 Handyhiker1 is offline
Don't know about the JB as I don't have one but my BFA can be wired so it will produce full out put at 120v. I plan on splitting this at the panel to feed both sides of the panel. That way both legs of the generator have eaual load. Just can't use any 220 stuff.
Old 11-10-2017, 10:56:26 AM
Leon N. Leon N. is offline
Hello Matt:
I did exactly what you are thinking when I installed my JB back in 1970. I built a 8 x 12 wood framed shed 125 feet behind my house. I build it on a poured concrete slab and faced the JB exhaust away from the house towards the woods. Over the years, this enclosure keep the JB dry, even when it was cold outside. Very little sweating or moisture getting into the enclosed shed. The concrete floor helps to stabilize the temperature, really! Took me a few years to figure out how to keep the mice out but I was successful in that also. I ran direct buried power, control and a 120 VAC battery charger line between the shed and my house distribution panel. I installed a JB monitoring home made panel as shown in the attached picture. All this has worked out just fine and the JB remains on standby today.
I found no need to monitor the JB temp, oil pressure etc. This 1966 designed unit is one hell of a machine. Very reliable and rugged, albeit noisy if standing next to it.
Old 11-10-2017, 01:07:38 PM
mjd325is mjd325is is offline
Leon,
Your setup is exactly what I'm envisioning. A couple questions: 1) How did you mouse-proof your unit? 2) I was planing a remote start/stop switch. I read the manual which calls for a "3 wire connection of a single pole, double throw, momentary contact, center off switch". I was wondering if I could use 2 Normally Open momentary switches instead and get the same result? Reason being I have these available, and I think they look cooler than the toggle switch. Attached is a photo of the switches I have in stock. I'd use one for start, one for stop.
Thanks,
Matt
Old 11-10-2017, 04:00:22 PM
Matt re your questions:
I finally mouse proofed my shed by installing a mouse condo outside and adjacent to the shed. A mouse condo consists of a bail of hay, you know the one's that are about 2x2x3 feet, kind of heavy. Sit it on the ground adjacent to the shed maybe a foot away from the external wall.. Cover it with a tarp or piece of plastic which is held down by a few stones or a couple of 2 x 4's. Never touch it again. Do not get curious and disturb it and I swear the field mice will be happy making tunnels and nests inside rather than come inside the shed through any opening as small as a nickel.
Your second question: I was wondering if I could use 2 Normally Open momentary switches ? The answer is no. Why? Because you must hold the switch in the on position until the centrifugal switch closes and kills the starter. You can tell when this occurs by monitoring the frequency meter. The stop switch operates just in the reverse, that is, you must hold the stop switch energized until the voltage/frequency drops low enough to open the centrifugal switch.
Yes, the JB start/stop is a 3-wire circuit.
BTW, you are not that far away, why not tool down route three, exit 34 and stop by. I can show you around.
Leon
Old 11-10-2017, 04:09:54 PM
len k len k is offline
I think the best mouse proofing is a tight shed or box around gen so mice can't physically get to it. I think this means no opening larger than 1/4 inch ( like 1/4 inch screens) , although for slots like under doors I'ld make it a lot tighter, like close to wind tight so it won't wear more open.
Found a little info on mice repellents , see my posts #, 3475 to 3478 in this link
https://www.smokstak.com/forum/showt...15080&page=174
Old 11-10-2017, 04:14:42 PM
JT240Z JT240Z is offline
Thanks,
Matt
Technically it would work but is not foolproof. The purpose of having a single double throw switch(on/off/on) is so you can never have both the start and stop switches closed at the same time. With your system, it could happen and would not be a good thing. The manual on my JC specifically calls that out.
Old 11-10-2017, 04:27:18 PM
Leon, with all due respect, I don't see why he can't use two separate N/O momentary devices. His photo shows a pushbutton operator with a N/O contact block. He could tie one side of each contact block together as the common ground, and use the other side of each as either the START or STOP signal. As long as both pushbuttons aren't pushed simultaneously, there shouldn't be a problem. If he has N/C contact blocks, he can wire them in series with the N/O contact on the
opposite pushbutton, as an safety interlock. This will prevent the generator from getting a start and stop signal together.
Old 11-10-2017, 04:53:21 PM
Yes Steve one can use momentary switches but they must work through an additional set of contacts that hold the start signal on until the Centrifugal switch closes. Likewise on the shut down.
LenK I truged your approach but iI was not successful. From a practical standpoint it is nearly impossible to build a tight shed with absolutely no openings. Even if you could do that, those critters will knaw their way in be it at the base board or the roof rafters soffits or gable ends--- eventually. They go all over the structure and will find the tineyist crack, slit or even chew their way in.
Before I installed the mouse condo, I covered all the JB openings with 1/4 inch hardware cloth. Then only to have a no-start situation when a mouse was found wrapped around a spark plug. I to this day do not know how he got in after all I did.
Old 11-10-2017, 04:59:01 PM
^ I think he would hold the START or STOP pushbutton for the same duration as a toggle switch. The N/O contact will remain closed as long as the button is pressed.
Onan ATS monitoring via serial connection ttyR2 Onan Generators 10 12-02-2015 11:45:12 AM
Power monitoring, load monitoring. imjustdave Generators & Electric Motors General Discussion 21 12-04-2014 01:55:18 PM
Onan....Remote monitoring.....found on Ebay AndersonMillTexas Onan Generators 3 01-20-2014 03:03:06 PM
Monitoring Onan Generator Amperes Leon N. Onan Generators 41 03-28-2013 11:01:08 PM
Onan Monitoring box Nubian Onan Generators 2 11-24-2012 01:03:20 PM
