Onan BF Will Not Crank
this thread has 38 replies and has been viewed 1498 times
Old 11-07-2017, 12:13:33 AM
signmakerdoc signmakerdoc is offline
Default Onan BF Will Not Crank
BF will not crank when start button is depressed, but resistor, and relay have been replaced
Old 11-07-2017, 12:48:26 AM
Default Re: BF Onan will not crank
Any more history on the set? Why were the resistor and relay replaced? Can you hear a relay click when you hit the start switch?
When you hold in the start switch are you getting voltage to the coil+ and fuel pump?
Is the starter solenoid new?
You should Please post the full model and serial number.
The Following 3 Users Say Thank You to nothingbutdarts For This Post:
Old 11-07-2017, 04:58:00 AM
lokay5's Avatar
lokay5 lokay5 is offline
"...resistor, and relay have been replaced"
For what reason?
1973 CK5 Blazer
Old 11-07-2017, 06:29:59 AM
JohnnyC JohnnyC is offline
Ah, did you replace the relay with an over the counter Ford relay from the autoparts store?
JohnnyC
New Jersey
The Following 2 Users Say Thank You to JohnnyC For This Post:
Old 11-07-2017, 02:54:55 PM
the unit is BF-3CR/16000B And No, it is not a generic relay, it purchased from Generator Specialists in North Lima, Oh. The resistor was changed because there was No resistance
Old 11-07-2017, 03:28:12 PM
History of the set, something that just happened? Has it been running fine till now?
Do you hear a click when you push the start button?
When you say relay, you are talking about the little cube relay correct?
The starter solenoid is original?
I believe there are at least 1 fuse in the front panel or maybe two, have you checked those?
The resistor you replaced, is it the charge resistor in the back generator section?
The Following User Says Thank You to nothingbutdarts For This Post:
Old 11-07-2017, 03:46:28 PM
yes, the one in the control box, original solenoid, and yes the charge resistor, and still trying to Get running, removed heads to remove carbon, new head gaskets, torqued 16-18 lbs, new plugs, new oil pressure switch
Old 11-07-2017, 03:46:40 PM
Gary Barber
POLLUTION just like craigs list Lst your post several times BECAUSE YOU ARE SPECIAL
Old 11-07-2017, 03:54:45 PM
Did it run before?
Do you hear clicking when you push start switch?
Fuses?
When you hold start switch, Do you hear clicking??????
Also when you hold start switch are you getting voltage to coil + ??????
Take a minute and answer these if you could.
Old 11-07-2017, 04:05:12 PM
Been working on it from time to time sine I purchased it over a year ago. In one of my earliest posts, I had the problem of it starting, running for a couple minutes, then shutting down, so the replacement of these parts was an effort to correct the earlier problem
Onan 20 no crank Crazy lb7 Onan Generators 11 04-17-2013 07:37:06 AM
Onan 6.5 NH will not crank idoscuba Onan Generators 6 12-10-2011 01:16:18 PM
Lombardini CRANK CRANK CRANK but no VROOOM LombardiniDiesel Vintage Diesel and Oil Engines 19 12-09-2011 08:20:31 PM
Onan CCK won't crank Joe Stewart Onan Generators 14 12-17-2010 12:32:11 AM
Onan 6.5 NH-3cr Won't Crank Ken Loggains Onan Generators 18 06-16-2009 09:41:33 AM
